Home > Pictures & Video > Croisier Blanch 2010 Pics
Page 3 of 3 <123
Glynparry25
I soo wish I could get the time to do something like that- Awesome pics Matt, looks like it was a blast Very Happy
Here is my input to toy porn:
I would give my right arm for one of these
Glyn
Post #23911 9th Feb 2010 9:42am
harveyg77
What size wheels/tyres is that 59-plate 110 DCPU running on?
Post #29695 13th Apr 2010 11:45am
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
It has 285-75-16 BFG Muds on Staun 8x16 rims Thumbs Up
Post #29710 13th Apr 2010 1:10pm
harveyg77
They look superb on her. Is that a size which has a lot of choice in brands/patterns? Mine is coming with stock 235/85r16, I assume with the width of the boost alloys I would not be able to go bigger than i.e. 265/75r16/
Thanks Harvey
Post #29746 13th Apr 2010 7:33pm
alantd
Thanks Harvey
You're not recommended to go past 265 on the 7" Boost rims. Some folks have but you're risking the bead coming off. If you're going up to 285 or beyond, you should go for 8" rims or bead lockers (or both).
There are plenty of tyre choices for 285 Thumbs Up One that started out as a 2.4 TDCi 110 XS
Post #29765 14th Apr 2010 12:25am
harveyg77
I guess bead-lockers (asthe name suggests) are a means by which the tyre's bead is mechanically locked to the rim of the tyre. But are they something built into special wheels, or are they something that can be bought and applied to any wheel and tyre?
Is there much difference in fuel consumption going up the tread width?
Thanks,
Harvey
Post #29773 14th Apr 2010 6:29am
alantd
bead-lockers are special rims. They are bolted on all the way round (so you need the rim to be drilled for the bolts).
As for fuel consumption:
In theory the weight of the vehicle won't change so at a similar pressure, the contact patch of the tyre should be the same (pressure = force x area). If the tyre is wider, the contact area will be shorter. That would mean the same amount of rubber in contact with the road, the same friction and the same mpg.
However, I'm sure there'll be other factors (you'll put more force on the tyre when turning so it might take more energy off in the bends; wider tyres tend to be more off-road biased and therefore have more heat loss, friction and a lower mpg...).
It's safe to assume that every modification to a LR saps your mpg Very Happy I installed rubber mats in the footwell and I'm sure it cost me 2mpg Whistle One that started out as a 2.4 TDCi 110 XS
Post #29783 14th Apr 2010 7:54am
alantd
See this thread for example bead-lockers
http://www.defender2.net/forum/topic3044.html One that started out as a 2.4 TDCi 110 XS
Post #29784 14th Apr 2010 7:56am
Sonic3d
Thanks,
Harvey
No need for special wheels Thumbs Up i have these fitted in my wheels and they lock both beads unlike most other systems Thumbs Up
http://www.staunproducts.com/beadlock.php
Post #29792 14th Apr 2010 10:32am
alantd
Sonic - they look quite effective. What do you do with the valve stem for the bead-locker? Do you have to drill a separate hole in your rims? One that started out as a 2.4 TDCi 110 XS
Post #29847 15th Apr 2010 1:48am
Sonic3d
Hi Alan
I was ok as i have Staun wheels that have the extra hole pre drilled, but to fit them in std rims you would need to drill another hole Thumbs Up
Post #29875 15th Apr 2010 12:48pm
alantd
Makes sense Thumbs Up
I'll add it to the list Wink One that started out as a 2.4 TDCi 110 XS
Post #29879 15th Apr 2010 1:26pm
Buzu06
Malta 1998 Defender 90 300 Tdi HT Alveston Red
[quote="Sonic3d"]
2 led work lights mounted on the rear facing forward helped with chain fitting in the dark Thumbs Up
quote]
Where can I buy a set of these LEDs? I'm planning to install them as reverse lighting but cant find them online
Thanks
Gary
Post #41063 22nd Sep 2010 3:09pm
Sonic3d
Hi Gary
They came from Watts Truck Centre in Gloucester near where i live Thumbs Up
Post #41076 22nd Sep 2010 5:36pm
Buzu06
Thats why I couldn't find them..
Anyone knows of sources online please?
Thanks
Gary
Post #41306 26th Sep 2010 8:11am
Page 3 of 3 <123
