Home > Technical > Air suspension on a 90 |
fitting air bags, compressor, pipe work and valves is not a big problem .. its the level sensors electronic side in more the problem .. or if it can be done manually with pressure regulators
mate had a classic range rover with air suspension fitted maybe 15-20 years ago that seem to work ok ..but worth all the work not sure |
12th Dec 2013 3:09pm |
Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 419 |
i am going to use festo maual regulators as this is an easy option and we have all the parts on the shelf!!
worth the hassel.......i'd say so, it makes it different as well as functional and comfortable. |
12th Dec 2013 3:12pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8149 |
Si Rafferty (X-Eng) ran a 90 on full air suspension not so long a go, try pming him on here. Cheers
12th Dec 2013 6:03pm |
rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548 |
On my old Disco 2 the pipes were a push fit into a a union on top of the airbag. I replaced the pipes from the compressor to the bags but don't recall there being any other valves.
I'm guessing the P38 bags are fairly similar. Be careful when routing the pipes, being plastic they tend to rub through if fouling any bodywork or the chassis due to vibration. 2015 90 XS CSW TDCi - Beautiful 2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome |
12th Dec 2013 6:24pm |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
I have considerwd air ride, but it seems yo work in the opposite to the desired affect. For instance on road the ride needs to be smooth yet firm, and off road needs to be soft but raised.
To gain the height off road means stiffening the ride. To drop the height on road means softning it. Im open to suggestiin on this as I still really like the idea of fitting air ride. Can I ask are you using a bag and shock setup or a bag and spring? |
12th Dec 2013 7:32pm |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2954 |
Each bag needs to be a different pressure for the vehicle to sit level
12th Dec 2013 9:00pm |
i have order new p38a air bags and i am going to use all festo valving gear and guages and have a manual set up for adjustment under my cubby box or in front of it. I was going to run the rears and the fronts as two pairs, but it can be dodgy, even with a compnsating valve in the middle. The lower you go the softer.....this is ideal coz you get a nice ride and it gives you the pimp look. I have ordered a vlair compressor from america, heavy duty system as this can be used for tyres and tools as well. I will have this all mounted inside with my 240v inveter as well.
I guess most people hate pimping up defenders, but i have had two years of off road mud and wading, now the time has come for performance and pimp?!......... |
17th Dec 2013 3:01pm |
rvdb Member Since: 04 Apr 2014 Location: NL Posts: 4 |
Can you share any updates about your project with us?! Thanks!
4th Apr 2014 10:07am |
It is nearly complete now, i have put all the air bags on and they are running fine just on Shreader valves so i have to manually adjust the spings. The ride is excellent, it is like a medium duty set of springs, but the harder you ride them, the softer they feel. What i mean is, (for those of you who have a disco 3 or new rangey you will know what i mean) if you hit a speed hump at 20 you feel it a lot!! but if you hit it at 50/60 mph, it just gets 'absorbed'
Will put some photos in my gallery as soon as poss |
4th Apr 2014 1:03pm |
Haha... Sounds good not stopping for speed bumps.
Looking forward to the pics. And also a installation guide and a list of used materials?? |
4th Apr 2014 1:05pm |
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 |
Any updates on this Will.i.am?
Im William and am at university just now doing electrical and mechanical engineering. Thinking about doing this to my motor but i would be more interested in the electrical side of things. I would be looking to run a micro controller and electrical valves to increase and decrease the pressure was you go so that it sits level automatically with weight and with cornering. How far did you get with your automation? William |
20th May 2014 1:45pm |
H3nry Member Since: 08 Jan 2014 Location: Heathrow Posts: 134 |
Will,
Any update on the air suspension? |
14th Aug 2014 10:03pm |
Are the P38 bags a straight swap for the springs
15th Aug 2014 12:19pm |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 |
Not sure if you guys have come across this, found it in my old bookmarks
http://www.x-eng.co.uk/sproklegrommet/lrsuspension/index.asp Interesting write up on an airbag installation. Cheers John 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
27th Aug 2014 5:44am |
