![]() | Home > Tdi > oil leak |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 ![]() ![]() |
Get under and see where it is coming from?
dondiddy Member Since: 13 Nov 2012 Location: Hamilton Posts: 224 ![]() ![]() ![]() |
Park it on a hill again then get under and have a look! Try not to get run over by the Landrover whilst doing this!
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 765 ![]() ![]() |
As above, get underneath and look, it may be necessary to polish the affected area so you can determine exactly where it is coming from.
As a rule, black = engine oil, red = gearbox oil & golden = transfer box oil. ONE LIFE, GET IT! |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 364 ![]() ![]() ![]() |
Is it common to leak from the timing case wading plug hole?
I think it might be the crank or cam oil seal. |
Can be the front crank seal. I usually change mine whenever I do the belt.
I recently changed the belt and all the seals but I see it is a little wet at the hole.
It's not dripping and I thought that I can change it with the next belt change. This is only if it doesn't get really bad. |
