Home > Puma (Tdci) > Puma Front Diff Broken
Page 3 of 3 <123
Caterham
thanks BW....
sounds like I'm going to need that 'cheap' run about. would be nice to find this is the problem and not the clutch but the moment I'm expecting it's going to be both.
- what's really peeing me off is that I'm thinking whatever the problem is it's basically been there since the very early but now I'm gonna have to pick up the bill Evil or Very Mad
Post #423806 15th May 2015 1:21pm
grizz
2014 Defender 110 Puma 2.2 XS CSW Corris Grey
I replaced both my diffs on my 2014 110 and was surprised to find the front diff a 2 pin .. For some reason i assumed they would be 4 pin ..
On a side note was i was amazed to see how much play was in the rear drive flanges after 3000 miles ..
Post #423937 15th May 2015 10:13pm
Caterham
Grizz. What did you replace them with?
I understand the rear flanges are more prone to wear - but at 3000 miles ! ? Sad
Post #423956 16th May 2015 5:10am
grizz
I've fitted a pair of ashcroft lockers
Post #423957 16th May 2015 5:24am
LR90XS2011
Caterham if you have the build sheet, or can get it from the dealer/LR it will state what diff is fitted. DEFENDER 90 TDCI XS,
Post #423960 16th May 2015 5:55am
Caterham
Thanks very much but from the information BW provided I'm sure it's a 2 pin version. Sad
Had enough of this and going to look into sorting new clutch, diffs and front axle complete....
Post #424000 16th May 2015 10:11am
If you want to pm your VIN to me I can check the build sheet. Won't be until Monday though.
Post #424004 16th May 2015 10:50am
Caterham
BW - many thanks for your kind offer. I'll pop out and confirm VIN for you shortly, from memory however I think it's;
0SCRAP/5PARE5/B1N/KNACK3R3D.
Anyone got a clue as to rough costs for a complete new front axle, a decent one be it land rover or otherwise. I don't needed anything heavy duty as it's not for off roading. just want it to be reliable / smooth. would like to think I could bolt something on and not expect any probs for 100k miles?
part reason for this is I have the 2 pin diff, problems elsewhere and the axle case might have the end drop off according to the recall notice I have Confused
Post #424051 16th May 2015 7:04pm
munch90
Trouble will be finding a late low milage axle that you know the history of , not from hard front damaged defender and also one not in the recall and one with 4 pin diff
but if you find one guessing 600-800 quid for complete low mileage axle
have you had any sit in when you drive to see what they say !
Post #424052 16th May 2015 7:21pm
Caterham
I guess like you say......finding the right one Confused
hoping to get clutch sorted on Friday so hopefully one set closer to being sorted and ready for some holiday mileage.
Thumbs Up
Post #424053 16th May 2015 7:24pm
Page 3 of 3 <123
