Home > Maintenance & Modifications > Defender 90 Puma Warning Lights
Gwynne_90
Hi. I've just bought my first Defender - a 2007 Tdci hard top.
Two of the instrument warning lights don't work.
The first is the full beam warning light - and I know the full beam is on - so I guess this is just replacing a bulb - Can someone advise how you get to it?
Second one is more confusing for me. I'm struggling to lock the diff (Hi Lo is fine). There seems to be almost no movement if I go Right to left (or vice versa) when in either hi or lo ratio - but much more lateral movement if I move it across from neutral - Is this normal? Either way the light doesn't go on - so not sure what's happening here?
I'm probably being an idiot (excuse is I'm a novice) Any advice most welcome.
Thanks.
Post #286603 30th Nov 2013 7:03pm
dorstsmith2
United Kingdom 2003 Defender 90 Td5 HT Caledonian Blue
look on the gallery i posted PDF instrument cluster removal
Post #286634 30th Nov 2013 9:19pm
Gwynne_90
Brilliant - thanks Dortsmith2 !!!.
Post #286668 30th Nov 2013 11:17pm
