Home > 130 > Clutch Replacement |
m_plewes Member Since: 17 Feb 2011 Location: Thirsk Posts: 11 |
The Discovery 1 was fitted with the same clutch as the 90/110 tdi, the 130 tdi's were fitted with a larger clutch plate and this can be fitted to 90/110's and Discovery tdi's. It's usually called the HD clutch, Valeo is the supplier Land Rover use.
27th Nov 2013 2:39pm |
Mblinko Member Since: 26 Nov 2013 Location: Dordogne Posts: 5 |
Many thanks
27th Nov 2013 4:25pm |
