Home > Td5 > Has anyone fitted a 6 speed box to a td5 engine
Defender_mad1990
England 1992 Defender 110 Td5 DCPU Bonatti Grey
Hi all I have just built a 110 crew cab using puma body panels but fitted a td5 engine and a disco td5 r380 gear box so I could fit the gear sticks next to each other but seems like it needs another gear I was just wandering if anyone has fitted a six speed box to a td5 engine
Thanks phil
Post #285387 26th Nov 2013 3:42pm
excossack
I think Ashcrofts were, at some point looking at a Puma 6 speed to TD5 conversion. Not sure if it ever happened. Maybe worth giving them a buzz? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #285406 26th Nov 2013 4:19pm
Defender_mad1990
Gear. Box
Will give them a bell tomorrow mate
Cheers phil
Post #285423 26th Nov 2013 5:18pm
Failing that, unless it's already got one, a 1.2:1 transfer box will increase the leg length a bit.
I've got one in my (Td5) 110, made a huge difference.
Post #285452 26th Nov 2013 6:53pm
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Which vehicle is that transfer box if that from?
Post #285465 26th Nov 2013 7:30pm
Glynparry25
Or go for a Ashcroft transmissions 1:1 Transfer box?
Glyn Dog Sheep
Post #285467 26th Nov 2013 7:32pm
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Generally speaking the preferred option to improve a TD5's road performance is to fit the 1.2 transfer box and get a decent engine map.
Post #285469 26th Nov 2013 7:33pm
Glynparry25
I agree with the 1.2 box- but depends on what your desired choice in tyre size is. Anything less than 33s (265/75/16) and you will still be sat at 2500-2600rpm at 70. Going from my Puma Defender to the gf's Discovery Td5 I feel like I am revving the t***s off it when on the motorway at 65mph.
1.2 box is so popular because there are hundreds of them floating around from broken Discoverys (normally fetch about £100) where the 1:1 box will need to be bought from somewhere like Ashcrofts (£550).
Handy link from the Ashcroft site: http://www.ashcroft-transmissions.co.uk/calc/ratio_calc.html.
Glyn Dog Sheep
Post #285471 26th Nov 2013 7:44pm
epictrail
How difficult is it to swap the box's?
Post #285478 26th Nov 2013 8:11pm
Glynparry25
Couple of hours work..... just need to disconnect drive shafts, disconnect linkage unbolt from the gearbox and then do the same in reverse to fit Thumbs Up
Glyn Dog Sheep
Post #285485 26th Nov 2013 8:18pm
grafty99
I believe that the 6 speed MT85 out of Aston martins/corvettes etc can be made to fit, read somewhere that a guy in America fitted one to a range rover classic so, similar transfer box with an adaptor plate? Confused 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #285500 26th Nov 2013 8:40pm
grafty99
just looked and used the Ashcroft ratio calculator the MT85 only drops the 70mph RPM by ~ 100RPM 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #285505 26th Nov 2013 8:49pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
yeah, a 1.2 box is the way to go.
It's really a fuel saver and ear saver on a long trip. epsecially when you are doing 110 to 120km/h, you'll appreciate it.
the lt230 is the same fitting, so you don't need to worry about it not matching. so it's a 1.41 box out drop it and drop in the 1.222 and you're done. it's purely a mechanical exercise, physically.
do bear in mind, if you had cruise control via the ecu, it will now only work in gear 4. so a 'speedo healer' can be fitted or you can get a cruise control kit.
pulling away in gear 2 might not be so easy now, if you are used to that. but anything on a slight decline slope, you'll pull away great in 2 and make good acceleration. The defender has migrated, leaving the owner behind.
Post #285598 27th Nov 2013 7:07am
m_plewes
That's because the 6speed box is fitted with the 1.2 transfer box. Just fitting the 6 speed box with 1.4 transfer box would make hardly any difference. The gain from the 6 speed is still having a low 1st gear. 1.2 transfer box on a tdi or td5 isn't great for setting off fully laden or towing.
Post #285684 27th Nov 2013 2:24pm
grafty99
I believe the MT85 is different to the MT82 fitted to the puma Confused 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #285862 28th Nov 2013 12:13am
