Home > Td5 > Clutch fork clip help
Millsy94
England 2003 Defender 90 Td5 PU Aintree Green
Hi all (again) ive just fitted a new spigot bush and an mid way through reasably though i went to fit the slave cyinder to find that the rod was missing, luckily it fell out of the bell housing not in, the issue is how do i refit the rod and clip in situe?? please dont tell me to slip it again any help will be great and a succesfull sotution will earn you a pint cheers ed
Post #284510 23rd Nov 2013 11:02am
Carlosbeldia
Columbia 2001 Defender 110 Td5 SW Epsom Green
You just support the end of the rod in the fork and then put the slave in its place. For the &%$&&/(&$%$ clip I have no other solution than taking all apart, but I was without it at least for 3 years with no issue at all (it broke in its place)
Post #285303 26th Nov 2013 12:58am
