Home > General & Technical (L663) > Last issue defender. |
Why would they even think about doing that? Irrespective of the fact if a V8 5ltr supercharged can be spooned into the Defender, it would require a huge amount of research and investment to match that thing with a compatible gear- and transfer box, compatible braking system and suspension system, etc. On top of that would come the homologation in the EU and maybe Australia which would not be an easy one. The Defender is just not suitable for such power plant, so Land Rover will not make the mistake of offering a boy racer last edition which once people are getting killed would give them negative publicity which they can miss like the plague. Think a last edition will be more cosmetically upgraded than engine wise, this has been the recent trend anyway, and that is probably a smart choise for such a historic design. You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
12th Dec 2013 5:58pm |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 |
The last V8s for Europe were the 50th edition vehicles in 1998, so I suppose if they produced something to a similar spec it could make sense. I doubt they will though, as it would nevertheless require loads of work, and they don't make that particular V8 anymore. Look forward to some stickers, alloys and fancy paint colours, and probably not a lot more.
Don't get me wrong I wish the last of the line was a super duper machine with all sorts of fancy things, but I just can't quite see it. 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
13th Dec 2013 7:58am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 |
I have to agree with the last few posts.
To add a bit more to the 'it wont happen' point of view. If a bigger engine were to be added and as mentioned bigger brakes etc etc. So would these changes require design changes that would then require costly type approvals. JE Engineering in Coventry have been removing Puma engines and slapping Petrol V8's into brand new Defenders for a few years now . These vehicles all head out to Saudi. |
13th Dec 2013 8:55am |
Aaron Member Since: 09 Dec 2010 Location: Surrey Posts: 46 |
Spoke to my dealer today, still no news on a/the last edition. Assuming MY2015 will be only run out edition models, I guess that would be announced in the summer for changes? They also have no information on the last time to order. I chucked a deposit down for one anyway! ex-MY1998 Defender 50th GB343 5.0L JE Supersports
MY2000 TVR Griffith 500 MY2003 TVR Cerbera SP6 |
15th Feb 2014 3:36pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3787 |
Yes, "Last time to order" (what you want) will be the interesting scenario. It would not be good to walk into your Dealership to order your Defender, only to be told, "The factory is not taking any more orders"? I mean you still may be, at that time, able to buy a unit off the floor, but customer build?..No.
Pickles. |
15th Feb 2014 8:55pm |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2226 |
Everyone seems to be in panic mode , the defender production Is NOT finishing . It's only in this country and those of EU regulations that it's being ruled out . Production IS continuing on a brand new line in China both in right and left hand drive to supply the huge demand in Eastern states and other countries whose regulations and emissions are not as stringent as the EU .
So unless they put a ban on imports ( unlikely ) then you will still be able to buy a brand new defender for yrs to come . |
15th Feb 2014 9:20pm |
Keith, where did you get that from, because, I don't think so.
Pickles. |
16th Feb 2014 5:10am |
Keith, unless you have hard evidence of that, really hard to believe. Can you substantiate your statement please? If this were true and if this news would be filtering out, it would be all over the internet I guess. Quickly googled "China Defender production" in various ways and come up with 0.... Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
16th Feb 2014 7:30am |
Even if they did continue production in China or Indian (and I can't find any evidence that this will be happening) it will not be possible to import them into the EU,so it would make no difference to us! Unless they are going to be re-engineered to allow import, in which case they may as well retain production at Solihull! 2011 110 USW
16th Feb 2014 9:11am |
Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 870 |
22900013A, you saved me the bother of typing the same thing. As a direct comparison, the 4WD Suzuki SJ410 continues to be made in India and marketed as the Maruta Gypsy; but no way would it be allowed to be imported into the UK.
Peter |
16th Feb 2014 11:18am |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 |
Should Defenders be built overseas for developing world countries, I don't imagine the same quality materials will be used, such as aluminium etc.
And the models built would probably have earlier or entirely different motors than those used in the UK, as has been the case in Defender global history. Should the aforementioned happen, Russia might be a candidate for Defender manufacture. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender |
16th Feb 2014 1:25pm |
Big Wheels, Russia? What makes you think that?
Not sure how well you know that country, but I do, and I can assure you that today they will not allow such a inefficient product of a bygone era to be produced in their country. I can assure you that today any foreign company wanting to establish an industrial operation in Russia will have to comply with the most stringent EU norms,........... and then some. No Russian company will be interested in this technology and production process either. FSU countries have some Defender enthusiasts like we all are, but the numbers are small. Essentially all FSU countries are typical FFRR buyers, 99% of which will be black color. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
16th Feb 2014 3:02pm |
Are you kidding - seen the quality used in Solihull now? It might just mean some of the parts have less far to travel before being fitted; and so will make the vehicle more green |
16th Feb 2014 5:48pm |
Who can we believe ? My info came from LR insider . Im as the same thought as you guys but one has to say what he hears . I bet there is a movement within LR to tell a different story to anyone who asks questions .
But as i mentioned , ( defender is far too important in many other countries for the company to stop its production . ) The other Huge burning question is that of 2015 ? How can it end in Dec 2015 when EU regs must be adheared to by March 2015 . Making end date of Dec 2014 . Its all very well LR lawyers trying everythin to prolong this date but EU is steadfast to March 2015 . Last edited by keith on 16th Feb 2014 6:27pm. Edited 1 time in total |
16th Feb 2014 6:20pm |
