Home > Puma (Tdci) > Oil filter housing
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Oil filter housing
Just thinking (always a bad sign)... is it worth having a spare oil filter housing for remote travel?
How solid are these things?
They are only plastic and I suspect will fail with time.
I actually like the oil filter setup on the Puma as I have found changing the filter to be quite easy. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #22752 23rd Jan 2010 3:49am
CapeLandy
South Africa
I would say its pretty solid looking and out of the way of trouble. But if cheap go for it. I reckon the fuel cooler needs protection.
Post #22753 23rd Jan 2010 4:37am
dm_td5
Devon 4x4 make a protector for the fuel cooler. I guess I'm more concerned with the oil cooler cracking when you are doing an oil change and then having to wait several days to get a new one flown in. It does sit up out of harms way. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #22754 23rd Jan 2010 4:52am
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
By the way the oil filter housing is exactly the same as the one on my peugeot 206. Might be cheaper from peugeot or a scrap yard. 130 crew cab
98 V8 Disco
Post #22763 23rd Jan 2010 12:02pm
dm_td5
I doubt it down here, Peugeot's aren't very common here. But thanks for the tip as there's been several Puma's wrecked and I may be able to get one off one of those. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #22784 23rd Jan 2010 8:14pm
