Home > In Car Electronics > Where to feed cables from battery box and cubby on 13MYXS90?
Baldinho
United Kingdom 2013 Defender 90 Puma 2.2 SW Orkney Grey
Hi
Am about to commence install of Alpine subwoofer plus swap out existing speakers for Focals. My XS doesn't have carpet just the stiff matting which is a very snug fit and appears glued down. What's the best way to route the cables from the battery box and cubby for the RCA cables and other wires in the most unobtrusive way to behind the dash without lifting up/damaging the matting?
Also for those with the Alpine SWE 1200 sub where did you put the amp? In the battery box?
Post #283743 20th Nov 2013 2:57pm
RobKeay
I just lifted up the carpet and found a hole with a gromit in. Pulled the gromit out put a hole in it and put the cables through. But depends on how thick your cables are. Might need to drill a bigger hole and buy a new gromit.
Post #283787 20th Nov 2013 5:29pm
Baldinho
Thanks
Gone in for annual service today so have asked them if they have time to run the cables through. I can do rest when I get it back.
Post #284053 21st Nov 2013 4:30pm
