Home > Td5 > Help, water in ECU! |
gor30 Member Since: 14 Nov 2013 Location: Krasnodar Posts: 3 |
Hi, friends!
Water in ECU. ECU- damage. I need ECU NND500020 SoftNNW501300 4195 Thank's! |
14th Nov 2013 1:30pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6124 |
On ebay you'll find the NNN000120 ECU and the NNN500020 ecu
Not many on there at the moment, but keep looking, they come up sometimes. Also you could try Ben @ www.venom4x4.co.uk I bought one off of him a few weeks ago. both the NNN500020 and the NNN000120 will do the job. |
15th Nov 2013 7:37pm |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 |
Roel,
Your mistaken.... any NNN500020 ot NNN000120 can be reprogrammed to suit either a Defender or Discovery application. It is the earlier MSB****** ecus than can not be easily changed. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
16th Nov 2013 7:04am |
Thank's all of You!
I find ECU on ebay.uk - Mastaz |
16th Nov 2013 9:18am |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 637 |
I have repaired several TD5 ECUs after drowning. In case of newer NNN it is good idea, in case od older MSB type ECU, it is cheaper to buy anouther ECU. "Drobek" = The Small One - Discovery 2, "BlufÃnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
16th Nov 2013 2:09pm |
OK learned something again. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
16th Nov 2013 6:12pm |
I need ECU NNN500020 SoftNNW501300 4195 |
17th Nov 2013 7:37am |
Can you open the ECU and make pictures of both sides of board inside? If it was drowned, there will be probably some small burnt parts. These can be replaced and the ECU repaired.
I may have some spare ECU - I have to look. But if you buy a new or used ECU, you will have to eneter in the ECU codes of your injectors, the right fuel map and have learnt it the security code from imobilizer. So you will need some some diagnotics. And one possible problém - you are outside of EU, so all packages has to come through the customs. "Drobek" = The Small One - Discovery 2, "BlufÃnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
17th Nov 2013 8:43am |
