![]() | Home > Maintenance & Modifications > Weld on shock mounts |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6133 ![]() ![]() ![]() |
There shouldn't be too much oil up in the "tubes" of the axle casings, but to be sure, as you'll have it up on axle stands anyway, just lift the side you're welding higher than the other side and let gravity sort it out.
