Home > In Car Electronics > led indicator relay problem
RickH
Question for the masses: what could make a relay flashing at an excessive rate?
Context: 2001 TD5 with no significant electrical mods. Standard incandescent bulbs and standard relay; indicators work fine. Swapped incandescents for led indicator units and standard relay; flash faster (expected this, obviously). Swapped relay for led load specific one and led indicator units; flashed so fast I could hardly count the rate.
According to the vendor, the returned relay tested ok, but they're sending a replacement. I've gone back one stage and am using leds with standard relay. But, I'll wait for the replacement relay and go back to standard set up, then swap the relay, then try one led at a time.
Any suggestions otherwise?
Post #280603 8th Nov 2013 5:34pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Try the new relay with LEDs first to save time,
LED relays normally have an a knob on the top to adjust the flash rate, if it didn't have this, it's probably not designed for LEDs..
Any link to the relay/vendor?
Post #280626 8th Nov 2013 6:31pm
RickH
I bought the RDX lights and their relay just to be consistent. I know I could have got a cheaper relay from somewhere else. They're all available on ebay.
Post #280629 8th Nov 2013 6:34pm
