![]() | Home > Maintenance & Modifications > Candle to Wipac- A how to guide |
david mitchell Member Since: 01 Jul 2012 Location: Meath Posts: 419 ![]() ![]() ![]() |
Fair play.
Ellisboy Member Since: 13 Oct 2013 Location: Deep South Posts: 539 ![]() ![]() |
Nice tutorial Thank you
Byronavitch Member Since: 26 Oct 2013 Location: NE Posts: 115 ![]() ![]() ![]() |
They do look well and good instructions, so do they work or do they get blown out when its Windy
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20717 ![]() ![]() |
Take care handling the Crystal lamps themselves too, they are an awkward shape and even more slippery if wet. WeWillWin🇬🇧🇺🇸
⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 702 ![]() ![]() ![]() |
Did mine last Friday .. quite odd to be able to see where you're going .. sort of takes the fun out of the randomness of it!
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
Thanks for the write up. If I recall if you have height adjustable lights you cannot twist them off due to the additional adjuster. You may have to remove the entire light unit and separate on the bench. BM52
3 Lions Member Since: 11 Jun 2011 Location: Geelong, Victoria Posts: 44 ![]() ![]() ![]() |
Are these the ones:
http://www.ebay.com.au/itm/390302730750?ss...4832wt_932 Col 1979 Series 3 109 FFR (ex Aust Army.) 2006 Defender TD5 110. 2012 Trackabout CT. |
@Bm52: I have no experiance with those so I'm afraid I couldn't comment but thank you for the heads up!
@3 Lions: They are indeed however I got mine via Paddocks ![]() |
Thanks Shaggydog,
![]() I have an Australian Defender uprated wiring loom to fit. Everyone on forums over here who have fitted them swear 100% the difference is amazing, Plus I bought some decent bulbs advertised on here from the UK. So if I do the wiring upgrade, the bulbs and the wipac xenon headlights I should have a really good set up, compared to the bog standard light set up I have at the moment, which lets face it, the lights on Defenders are pretty poor. Col. 1979 Series 3 109 FFR (ex Aust Army.) 2006 Defender TD5 110. 2012 Trackabout CT. |
Australian uprated you say?
I'd be interested to see this as my looms are mainly scotchlocks and bullet connectors from the previous owner which cant be helping matters.... Where did you find them or do you have to build them up yourself from scratch? |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
Make the light switch a switch
Run high current cable down to the lights Switch through a relay |
Just a quick update.
Wow what a difference it has made- I was slightly sceptical when I first did it thinking how much of a difference it will make but have now found it to be a huge difference! Have just done my spot lamps too and found them to have made a big difference too. Overall very pleased with the upgrade- money well spent. |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
So much difference for dipped beam as well
![]() An equally good alternative to the Osrams are Philips H4 X-treme vision. They have chrome tips so blend in nicely with the reflector when not switched on. http://www.amazon.co.uk/Philips-X-treme-Vi...h4+x-treme Osram do the Nightbreakers with gold tips as a Limited Edition http://www.amazon.co.uk/Osram-Night-Breake...+unlimited Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender Last edited by BigWheels on 16th Nov 2013 7:08pm. Edited 1 time in total |
I have the Philips in mine, very pleased.
![]() ⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
