Home > Technical > Clutch plate
2dae
Australia 2008 Defender 110 Puma 2.4 SW Santorini Black
Clutch plate
Hi all looks like my gearbox is comming out for a rebuild as firt gear sounds a bit funny
Has any one got any tips on rebuild ???
Also i really want to upgrade my clutch and pressure plate to a solid fly wheel and heavy duty clutch
as the dual mass ones are quite useless
Ive had three cluthes since new and been told a solid flywheel would benifit car greatly
Post #278927 2nd Nov 2013 8:15pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
The Puma doesn't have a Dual Mass Flywheel, the Td5 did. This might be useful -
http://www.defender2.net/forum/topic13662-15.html Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #278975 2nd Nov 2013 10:19pm
If your Defender is an 08 Puma as your profile suggests, then you already have a solid flywheel, they all do. There was a number of issues with early clutches (springs falling out of the driven plate) and you may have had problems, but the current plates seem to be OK.
Edit: beaten to it again!
Post #278976 2nd Nov 2013 10:20pm
