![]() | Home > Land Rover Customer Relations > Oil for 2.2 Tdci |
CRC@LandRover Verified Account ![]() Member Since: 25 Mar 2013 Location: Coventry Posts: 383 ![]() ![]() |
Hi Rick,
Can you PM me the last 6 digits of you VIN and I will give you the correct details. Many Thanks Mike |
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 ![]() ![]() ![]() |
Hi,
I am also interested with your answer ... I have also a def with puma 2.2 with DPF and I know that I am not using the right oil. no informations in the ownerbook, in one manual they talk about WSS-M2C913-B. unfortunally, I am using WSS-M2C913-C .... ![]() in TOPIx 5W/30 – WSS–M2C934–B regards, Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
Rick81 Member Since: 08 Sep 2013 Location: Wiltshire Posts: 108 ![]() ![]() ![]() |
Thank you Mike, PM sent with last six digits.
Hi Rick,
The correct specification oil for your vehicle is as follows: 5W/30 – WSS–M2C934–B Many Thanks Mike
Thank you Mike, still not sure which "castrol" oil (as recommended in my service book and hand book.......) that relates too - the hand book states the castrol oil for all other applications........
If you could clarify the castrol oil (as per handbook....) I require that would help, thank you.... |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2237 ![]() ![]() |
Mobil 1 15/30 fully synthetic for me .Not cheep but 1st class and changed every 4000miles
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
http://www.ebay.co.uk/itm/Castrol-Edge-Pro...1351wt_959
Castrol EDGE Professional C1 5W-30 is suitable for use in vehicles that require a 5W-30 lubricant that Meets Ford WSS-M2C934-B specification. Pete |
Axel Member Since: 22 Jun 2011 Location: Bochum Posts: 107 ![]() ![]() ![]() |
http://www.liqui-moly.de/liquimoly/produkt...db=web.nsf
![]() Axel |
