Home > Td5 > Water from the driver speaker ??
Jack77
United Kingdom 2006 Defender 110 Td5 XS CSW Epsom Green
Big Cry Don't know if it's because of the Storm or not...yesterday morning I have noted some dripping from the driver speaker, inside the car no sign of water at all and I have checked everywhere.
Air vent seems normal and the dash is completely dry.
This morning again a bit , do you have an idea where this is coming from? I have the feeling I have to remove all the aircon bit to check .
Thanks for help
PS the speaker works perfectly! Rolling Eyes
Post #277766 29th Oct 2013 2:26pm
Iirc there is a small channel just behind there which is a common water leak area. Others can give you more detail on that.
If I was you take the speaker out let it dry and disconnect it too, it could get damaged / short and blow a fuse. GBR
Post #277767 29th Oct 2013 2:29pm
Jack77
Thanks, will have a look onto this tomorrow morning that I'm off, is there a way to seal it?
Post #277772 29th Oct 2013 3:04pm
were you listening to wet-wet-wet ? Rolling with laughter
i'll get my hat
Post #277780 29th Oct 2013 3:36pm
Jack77
Post #277787 29th Oct 2013 3:54pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
i'll get my hat
I think it could well have been Handels water music.
dj 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #277808 29th Oct 2013 4:40pm
Was it Purple ?
Post #277817 29th Oct 2013 4:54pm
johnnyd
You weathermen you.......... 2008 TDCi 2.4 XS CSW
Post #277855 29th Oct 2013 7:02pm
