Home > In Car Electronics > ?????
Lewisgregory8
2014 Defender 90 Puma 2.2 HT Fuji White
Ive ordered a new 90 hard top, i didn't want to get a radio as i think its expensive for you actually get.
What is involved in me fitting the radio? Can i just plug a radio straight in etc?
It said on the spec it comes with radio prep, which includes an Arial...
Post #276849 26th Oct 2013 10:08am
In other words it should have the wiring in ready for a quick fit. Thumbs Up if it's a 2.2 it might need a loom adaptor though.. KEEP CALM AND Drill ON
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #276852 26th Oct 2013 10:13am
Lewisgregory8
What do you mean by Adaptor loom?
I have little knowledge with radios
Post #276853 26th Oct 2013 10:14am
The loom plug on the Defender 2.4 was ISO which is a market standard which is a direct fit for basically all makes and models of branded radios. The 2.2 they made it more specific (silly IMO) which means this easy compatibility is no longer there, therefore you need an adaptor. This will convert the Defender specific plug into and ISO plug which will be compatible with the radio/HU you wish to fit. KEEP CALM AND Drill ON
Post #276855 26th Oct 2013 10:20am
Lewisgregory8
Ah i see.
I think i will pass the job onto my father
Post #276858 26th Oct 2013 10:24am
Cheshire110
It's perfectly doable yourself.
Get yourself down to halfords or equivalent, they'll sell the DIN cage and the adaptor look if you need it. They'll at least have a look in the car and tell you if you do need it.
Some radios come with the cage actually now I think of it so probably just need the wiring if anything.
Not a tricky job, any halfords person will be able to fit it if you want, or really anyone who's owned a car Whistle Cheers, David
Land Rovers of all shapes S3 onwardsโ€ฆ Daily is a 110 V8.
Post #276949 26th Oct 2013 4:01pm
