![]() | Home > My Defender > Rust proofing new defender |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20749 ![]() ![]() |
Not contemplating doing it yourself then? WeWillWin🇬🇧🇺🇸
clovelly14 Member Since: 08 Oct 2013 Location: Chester Posts: 25 ![]() ![]() ![]() |
Ummmm , no Audi S4
Defender 110 |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 ![]() ![]() ![]() |
Nick Gresty at Rustmaster in Mobberley 07748-274966
Actually, realising now I can do it myself, after reading into it. Thought it was some major treatment. ,I have a lot to learn .
![]() Defender 110 |
Thanks SMB Audi S4
Defender 110 |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
Hey it's David from sandiway / Cheshire area
![]() I was thinking same lines as you and decided to do it myself, not too bad a job tbh if you get the right stuff. I reccomend getting the genuine waxoyl pump & chassis injection nozzle (read 'bit of tube with nail in the end') and warming the waxoyled beforehand to aid spraying. I wore overalls but it can go through so wear scruffy clothes too! And expect your hair to be ruined after too... Need to do my 110 sometime soon, and luckily I have had some ramps made up which makes it easier! Also if you haven't seen it already, see the corrosion prevention guide here on the forum: http://www.defender2.net/forum/topic10467.html Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Also will send you a PM now Cheers, David
Do it yourself! It's the only way to really learn! I've done 6 (?) now, and it's a piece of cake if you know what you're doing!
![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
