![]() | Home > Puma (Tdci) > Holding its revs |
bobcat Member Since: 11 Feb 2012 Location: United Kingdom Posts: 12 ![]() ![]() |
Thank you.
Norm4n Member Since: 31 Aug 2012 Location: Surrey Posts: 329 ![]() ![]() |
Top of transfer box?
myonehere Member Since: 03 Mar 2009 Location: Worcester uk Posts: 153 ![]() ![]() |
thanks
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6324 ![]() ![]() ![]() |
Just trying to understand something.....
Just checked the clutch switch which appears to work fine....goes from v low resistance to v high as the clutch pedal is depressed / released......I then forgot to replace the switch and the engine revs really hang when changing gear. I presume this is right but what I can't get my head round is why the revs hanging on a gear change isn't noticeable when the switch is connected?? ![]() |
Can anyone tell me.....
Clearly you can adjust T bite point of the clutch (adjacent bell housing) ... can you adjust the 'bite' point for the clutch switch which activates the Rev hold features? |
