- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
mikelike
Hi guys need help regarding my 130 . My 09 puma 130 only has the one coil spring at the rear and have been told they came standard with the inner helper spring . I put a 1300 kg camper on the back and she dropped straight onto the bump stops.Is this the same coil as a 110 or is it heavier ? Unladen the 130 rides way rougher than my 110 truck cab/tray so does seem to be heavier than a 110.So I went looking for an airbag but can only find polyairs rated at 570kg a bag, I want to carry 1400kg in the tub when camper on and drop air when off. Any suggestions please oh also will my 130 still be a 3500gvm with helpers springs missing ?? Cheers Mike
20th Oct 2013 9:30pm |
