Home > Maintenance & Modifications > Defender Flip Key |
Andy80 Member Since: 31 May 2013 Location: Essex Posts: 490 |
Nice little project....Well done Working towards Carry on camping!
12th Oct 2013 9:43pm |
this is the prototype BEFORE the NO-FLIP version as you know...
The light switch touch the keys and not reach the full ON position. Click image to enlarge Click image to enlarge SO I chose the "normal" version because not all peoples want/are not able to bend the switch column Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
14th Oct 2013 9:16am |
dotom Member Since: 04 Feb 2012 Location: Dortmund Posts: 90 |
Hi Daniele, you can put the light switch on the right side of the steering column, close the hole on the left side with some GFK, wrap it in leather and everything is fine. Just saw it on a defender they modify here in Dortmund. How about the flip key, did you modify one?
Greetings Tom |
15th Oct 2013 5:05pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Mine is close to the light switch but not so close that it causes a problem.
I'll take a photo |
15th Oct 2013 5:24pm |
No room on the right side Click image to enlarge Iniitially I started my project with the same key as Tiger, but the final one was a different version Click image to enlarge By the way my keys is out of stock....... Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
15th Oct 2013 7:14pm |
Hi Daniele, so your key is an original LR model?
From which car? May be someone has one in stock... |
16th Oct 2013 4:42pm |
no, new project based on Renault traffic case.
see on the Avon diagnostic web site (google it) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
16th Oct 2013 10:06pm |
Hi Daniele, i did, thank you. Do you plan to run a little series again if it works? If you do so, please count me in;-)
Greetings Tom |
20th Oct 2013 10:47am |
