Home > Technical > TD5 washer jet
Laurie
TD5 washer jet
Coming home from Somerset in heavy snow on Tuesday, the wipers were hammering snow down onto the bulkhead. I stopped occasionally to clear it and save damage to the wipers.
The snow slowly cleared from the bonnet as it warmed up and I spotted a black lump embedded in it.
Pulling over, I grabbed it to find it was my washer jet housing. They're just 'push on' units and the wipers had slowly hammered the snow onto it until it became detatched.
Glad I rescued it - dunno how much they cost but knowing LR prices................
Post #21494 7th Jan 2010 4:36pm
mse
If its the little black thing the jets come out of ... only a £1 or so.
My problem is the fluid in to doesnt freeze, but the snow/spray melts on top and freezes it requiring defrosting first.
Although having said that it getting really cold now Mike
Post #21496 7th Jan 2010 4:42pm
These "unclip" themselves, usually when the washer fluid freezes and expands.
once it's all thawed, place it back on the "stub" thats sticking out of the bulkhead and give it a good thump, it should clip back on....
....unless the stub itself has broken (i've had that before), in which case you'll need to remove the dash top panel (about 12 screws all told) to (try and) get access to the nut on the back of said stud.
Post #21773 10th Jan 2010 3:49pm
fekete
I've super glued mine on. sick of losing it at the jet wash Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #21774 10th Jan 2010 4:13pm
gtveloce65
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Epsom Green
That explains why it was missing on my old Td5 (should have checked the washers when i bought it!). Will keep in eye on the puma one - it certainly takes a while to defrost, no matter how concentrated you make the screen-wash. But it is right in the line of cold airflow, so at -5 degrees static, the wind-chill must be in minus double figures 1953 80
1965 Alfa Romeo GT Veloce Sprint
1980 Fiat 124 Spider
2008 110xs
Post #21942 12th Jan 2010 5:31pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
I ran my washes on neat fluid at -15c ambient god knows what it was windchill had no problems Original Member Pie n Pea Club.
110 HCPU Tipper
Post #21949 12th Jan 2010 6:24pm
