![]() | Home > Technical > Puma stalling fuel supply issue |
Sackspeed Member Since: 03 Oct 2013 Location: Glasgow Posts: 3 ![]() ![]() |
Have you checked the infamous loose yellow relay under drivers seat?
Macpaul Member Since: 25 Mar 2013 Location: SW Surrey Posts: 439 ![]() ![]() ![]() |
Fuel tank vent pipe clear in the rear nearside wheel arch?
Or just try a short drive with a half empty tank and take the filler cap off to test. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
Thanks chaps, but all these have been tried. Breathers all clear. Fuel line all clear. Tank clear. Cold filter clear. Fuel pump ok. Still no fault codes. ECU is fine.
Not stalling any more but running gutless. THIS IS DRIVING ME MAD! Any more thoughts? |
Check the crankshaft and camshaft sensors. And the relief (over pressure) valve (must be closed) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
Still not solved. Thought I'd post up what's been tried in case it helps someone:
Swapped with another Vehicle and then swapped back again: ECU Air Flow Meter Crank Sensor Air charge Sensor Removed fuel lines & ran from a can – (better at this stage) Filled with 20Ltrs of diesel. Road tested, vehicle would not stall but noticed lack of power. Swapped injectors Remove fuel tank and fuel lines and checked for blockage, dirt etc… Checked intercooler pipes Swapped fuel pump Remove Front pipe exhaust to check cat was not blocked Swapped turbo I'll update in due course. I'm starting to want to ditch for a 2.5N/A Wolf 110. |
I know this is turning into a bit of a monologue, but i'm updating to in the event that it will be helpful to someone in the future.
My problem has, apparently, been identified: The fuel pump has a high pressure release valve and this was disintegrated. The symptoms were lack of power like a broken turbo, but the turbo was not broken. This seems to have been the cause of the stalling when the fuel tank was on the red light. With a head of fuel, the stalling went. |
Decent of you to follow this (hopefully) to its conclusion.
All knowledge is good and might help someone. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
Just to finish this thread off:
Yes this issue was the fuel pump high pressure release value which had failed. Let it be a suspected part if you experience unexplained stalling and loss of power. This had never been experienced by the highly experienced Defender mechanics that i used. Over and out. |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6324 ![]() ![]() ![]() |
110seb
out of interest do you know how easy / what was involved in replacing it? glad to hear its sorted ![]() |
Caterham, 'no' is the simple answer!
I didn't get the chance to spend any time with the 110 while it was being played with. I do however know that the high pressure release value is not an integral part of the fuel pump itself, so in theory might be relatively easy to get to. To replace start to finish i would doubt would be more than a 2 hour job for a mechanic. A cheap part too. |
item n° 23
P/N LR006866 ![]() Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
dgardel ??? what is it?
110seb - I think the hp valve is on the side of the common rail (nearest the bulkhead?). - as ever I stand to be corrected by those who know. looks easy to replace but we're potentially talking BIG pressures and air locking the system so if its a cheap part AND easy to fit I might well be lining myself up for a new one ? ![]() |
MD5 Member Since: 02 May 2011 Location: Italy Posts: 143 ![]() ![]() |
Even my car has accused the same problems as that of 110SEB. The extreme randomness of the problem, the absence of error codes and the inability to reproduce the fault in the workshop made it impossible to have a clear diagnosis of the problem.
All attempts to repair during the warranty period have failed, many parts replaced: - Turbo - Fuel tank cleaning - Fuel filter + filter head - Fuel lines between tank and filter head - CHT sensor Once out of warranty, worried that the car could stop on a dangerous road (motorway, gallery, curve etc.), I requested the workshop to do a one-shot replacement of the following components: - Fuel pump with VCV valve embedded - The common rail pipe with both valve/sensor at the ends - ECU - The entire engine cables/harness - The entire fuel lines between fuel filter head and fuel pump After 3 months and several thousand kilometers traveled, everything is ok. I hope that the problem is now gone. |
MD5
are you saying the following items have been completely replaced? - Fuel pump with VCV valve embedded - The common rail pipe with both valve/sensor at the ends - ECU - The entire engine cables/harness - The entire fuel lines between fuel filter head and fuel pump glad all is going well ![]() |
