Home > Td5 > nanocom group buy ? |
appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630 |
How much are they?
30th Sep 2013 8:30pm |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 |
Just over £300 direct on their site - but I presume there will be postage and maybe Import duties as they are located in Cyprus. On eBay they sell new at £384.
30th Sep 2013 8:46pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
No import duties because Cyprus are a member of the European Community (When it is to their advantage).
Postage is always very good with them (DHL normally takes 24-48hrs). The D2 boys club are ordering in a group purchase in October..... might be an idea to join forces and get an even bigger discount (They already have 12). Glyn |
30th Sep 2013 9:08pm |
That sounds good - can you share a link to the D2 folk ?
Stephen |
30th Sep 2013 9:14pm |
http://www.thed2boysclub.co.uk/viewtopic.php?f=2&t=30999
Hopefully that will work without needing a log-on Glyn |
30th Sep 2013 9:20pm |
Glyn, Unfortunately not so it seems! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
30th Sep 2013 9:24pm |
If need be I will act as a point of contact between the two.
Glyn |
30th Sep 2013 9:34pm |
I actually applied to join that site but never got my confirmation email... Maybe went into junk ....
I'll try again! |
30th Sep 2013 9:48pm |
They vet ALL applicants- Normally takes 24-48hrs to receive confirmation.
Glyn |
30th Sep 2013 10:00pm |
I just tried to log in and post and its worked - the confirmation email must have gone into my spam folder.
Looks all good now though Thank you! |
30th Sep 2013 10:05pm |
austinhealey55 Member Since: 09 Sep 2013 Location: Lusaka, Zambia Posts: 24 |
I already own a Nanocom but thought I'd pass along an experience I had with mine. There is a feature it has to set a coolant temp warning, and although it's not terribly loud it went off while on a trip in the mountains, towards the end of a long day of driving. The gauge was of course where it always was -- reading normal. I thought that it must have been an error or something, but I got out and did a quick check and indeed the engine was very low on coolant -- a fuel cooler pipe had sprung a leak. I credit my Nanocom w/ saving my engine that day.
I've moved my ODB connector to under my stock box, and routed the cable around the back to the side of the driver's seat (RHD). My Nanocom stays there and I always have it on during long drives. (A ziplock bag over it to keep dust and water over it isn't a bad idea). Photo attached of it in situ. |
1st Oct 2013 5:49am |
Macpaul Member Since: 25 Mar 2013 Location: SW Surrey Posts: 439 |
Off topic but can you tell me where the coolant temp alarm is on the Nanocom. Didnt realise it could do this - and I wonder what else.
All I've used is the fuelling inputs screens trying to fix a problem. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
1st Oct 2013 1:02pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6613 |
You will already receive a discount with Blackbox Solutions as they sponsor (quietly) Defender2 1988 90 Td5 NAS soft top
2015 D90 XS SW |
1st Oct 2013 1:51pm |
Macpaul: If you go to the instruments view, scroll over to the last page and there is a settings menu there. That's where you can set a coolant temp warning.
1st Oct 2013 4:20pm |
