Home > Puma (Tdci) > How to remove the radio blanking plate? |
Colin Member Since: 29 Dec 2009 Location: UK Posts: 12 |
Hi,
I am now the proud owner of new Defender 90. I want to fit a radio, but I can not figure out how to get the blanking plate out. Anyone done the job before, or anyone know how to detach the radio/switch/heater pannel on the centre of the console? I have tried undoing the two torx screws on the front, but nothing seemed to come loose. Cheers, Colin |
5th Jan 2010 9:08pm |
scatt Member Since: 24 Aug 2009 Location: nottingham Posts: 103 |
the panel just clips in, it should just pop out. But if you dont have a radio you won't have any speakers!! you can modify and fit aftermarket ones or buy some from landrober but there about £45 each
5th Jan 2010 10:42pm |
shingwell Member Since: 13 Mar 2009 Location: herefordshire Posts: 45 |
But you will have the wiring in place (mine did, anyway!) |
6th Jan 2010 2:38pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
if you dont want the blanking plate and its not coming out just drill a hole in the middle and pull! Mike
6th Jan 2010 5:42pm |
Thanks for the replies guys.
Glynparry25, I will post some photos this weekend, when I can get out into the daylight to take them. As Scatt said, the panel just pops out with the aid of some leverage from a screwdriver. And the wiring is all in place. Cheers, Colin |
7th Jan 2010 9:49pm |
Hi,
Radio successfully installed, including a pair of speakers. Needed to fettle the hole for the radio and spent a while with the DVM to find the new dud fuse that had blown. Now I can start the hunt for load bay liner. Anyway, as requested here's a photo. Cheers, Colin |
11th Jan 2010 10:05pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
She is looking nice there Colin .
Glyn |
11th Jan 2010 10:56pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Lovely. Keep it simple - I like One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
13th Jan 2010 8:40pm |
