![](templates/vbnew/images/spacer.gif)
I'm after a picture of the cooling pipes on a 10P defender Td5 engine. around the header tank and fuel cooler area.
I think I plumbed in my heater incorrectly, as one pipe is toasty hot (Coming off of the LH side of the engine) into the heater, and the other is cold, which connects to a T piece just down from the header tank, and the 3rd pipe from said T piece goes into the fuel cooler.
This T piece does have a 4th outlet which I blocked off with a bolt and jubilee clamp, but I don't know where it should go to.
Either way, I think the heated should flow back into something with some movement, as at the moment I've got naff all heat
Thanks all.
25th Sep 2013 7:47pm |
