Home > Technical > Bluetooth pairing |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20351 |
What phone / HU are you intending to use? Have you searched via BT on the phone?
$W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
24th Sep 2013 8:18pm |
Cakey Member Since: 19 Feb 2013 Location: Cheshire Posts: 468 |
If it's the alpine , just press bt button , then pair with phone , no code needed
24th Sep 2013 8:26pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8025 |
std alpine, BT button doesnt seem to do much of anything/doesnt let the phone pair.
std def HU. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
24th Sep 2013 8:28pm |
Do you not have the manual? Some of these things do silly things like where you have to hold down the button for a few seconds. It should be relatively simple though..
On mine it's always on and phone simply finds it and then pairs. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
24th Sep 2013 8:33pm |
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 |
With mine, all I had to do was search a list on my phone of bluetooth units to connect to, and it found the make of my head unit, and I told the phone to connect to it. Now it connects every time. I think there is more to do on the phone itself to connect, rather than telling the radio to connect... 1998 110 300Tdi White Hard Top
24th Sep 2013 8:36pm |
MartyM Member Since: 25 Aug 2013 Location: Belfast Posts: 17 |
This may help:
http://landrover45.nextgen-technology.net/...bility.pdf Most Landrover headunits use "2121" as the pin code to pair with bletooth devices in my experience. M |
24th Sep 2013 8:46pm |
If you know your VIN number and your phone type & you have a standard LR Alpine unit you can follow these steps :
http://www.landrover.com/gb/en/lr/owners/b...ty-centre/ M |
24th Sep 2013 8:57pm |
http://landrover45.nextgen-technology.net/...140912.pdf
Here is the official guide from LR. M |
24th Sep 2013 9:00pm |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 |
Which phone you using. There are known issues with BT on the iPhone 5 as I found out 2007 TD5 90 Hard Top
24th Sep 2013 10:13pm |
Mine works perfect with iPhone 5 , better than the rrs
25th Sep 2013 12:31pm |
shaun.mobile Member Since: 12 Dec 2011 Location: England Posts: 156 |
Make sure your phone is set to "discoverable"
25th Sep 2013 7:20pm |
no don't have the manual.
cheers guys for all the tips will follow links and see how it goes. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
25th Sep 2013 8:41pm |
Hifonics Member Since: 11 May 2010 Location: Bridgwater Posts: 63 |
I paired mine without the manual James, if all else fails give me a shout, not sure if I am coming to the de-cider or not
26th Sep 2013 6:14pm |
