![]() | Home > Td5 > front diff? rumble |
do you have a suspension lift ?
ironman19 Member Since: 17 May 2013 Location: cambridge Posts: 7 ![]() ![]() |
the suspension is completely stock.
Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 419 ![]() ![]() ![]() |
it could be one of the front prop bearings loose coz that happens on mine as well. The furthest front uj had a tiny bit of play in it and when i pressed in a new one, it stopped and sounded good again.
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2227 ![]() ![]() |
I have exaactly same rumble under exactly same conditions from the Rear . 100% positive its the dif .
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8162 ![]() ![]() ![]() |
mileage? Cheers
