Home > In Car Electronics > Dash Lights
sweatysock
United Kingdom 2007 Defender 110 Puma 2.4 CSW Indus Silver
Dash Lights
Hi, my dash light linked to the temp gauge has packed in. I am not good at electrics so in advance of stripping dash I was wondering if there is a separate bulb or is it integrated into the temp gauge unit.
I have a 05 TD5, thanks in advance Sweatysock
110 CSW TDCI (Puma) 2007
Post #265384 10th Sep 2013 8:48pm
excossack
If its anything like my 1999 td5 then from memory, its two screws under the dash pod (one by heater cold/warm & and one by the fan speed) and a couple either side of the dash pod.
The pod should pull forward and you should be able to see all the wires.
The lights are inset into the gauge you will need a set of sturdy tweezers or thin long pliers to remove the light bulbs by twisting them out.
You might need to unplug some of the wires that go into the back of pod to get enough room to move it around.
Good luck! 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #265391 10th Sep 2013 9:00pm
VeeTee
Netherlands
 Cheers, Vincent
MySite
Post #265409 10th Sep 2013 9:36pm
sweatysock
Thats great, very helpful, thanks Sweatysock
Post #265757 11th Sep 2013 6:16pm
sweatysock
duplicate post Sweatysock
Post #265758 11th Sep 2013 6:16pm
