![]() | Home > Tdi > 300TDI Rear exhaust without silencer |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 ![]() ![]() |
Yes, the TD5 rear section fits on a 300TDi, and no, it has a silencer.
![]() Click image to enlarge Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 ![]() ![]() ![]() |
Hmm ... That's not the one I was thinking of then ...
There's one that come from the rear joint, follows an 'S' straight out the side in a similar way to standard, but without the canister. Just had a look on the Fische's, but cant find it? Was definitely a Fische picture I remember though!!?! |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 810 ![]() ![]() ![]() |
Never seen a rear section without a silencer box, but sounds exacly what i am looking for.....
Something like this maybe?
Would this fit? ![]() |
Answering my own question here, but worth it I think for anyone else ...
4527 is the later 300TDI set-up which ran the much shorter 4526 mid-section ... So 4527 wont fit the early type. However, if you get the 4526 straight through mid section (TF552 for Terrafirma S/S) and the OEM 4527, then it will bolt-up to the downpipe of even the early type just fine. That's my plan I think ... I'll just shift on the bit I just bought! Does this sound correct to everyone? |
