![]() | Home > Puma (Tdci) > HCPU into Station Wagon, missing wiring plugs? |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 506 ![]() ![]() ![]() |
Unfortunately, Land Rover don't use "one size fit's all" harnesses
![]() As an example - for the 2007MY Defender, Microcat lists 54 x different main (bulkhead) harnesses. There are only 3 x chassis harnesses listed - 1 for the 90, 1 for the 110, and 1 for the 110HCPU/130 So, you won't have the wiring or connectors for the high level stop lamp, heated rear window, or wash/wipe, in your chassis harness. You will need to change the chassis harness to - LR016442 (which has superceded YNN501070), or add the extra wiring and connectors. But, before rushing out to order a new chassis harness, it would be wise to check that the wiring for these circuits is present in C0376 on your main harness - ![]() You are looking for - White/Black trace in cavity 12 (heated rear window) White/Green trace in cavity 13 (rear wiper live) Black/Green trace in cavity 14 (rear wiper switch circuit) ![]() (Connector 'face' shown) Wiring for the tail door courtesy light switch and central locking are part of the roof harness, which you will need to change for a station wagon version. Again, the wiring for these circuits will have to be checked for in the main harness, at the main harness to roof harness connector C0488 . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
konamac Member Since: 08 Sep 2011 Location: Namibia Posts: 10 ![]() ![]() |
Thanks Paul for the fantastically detailed reply
![]() I will report back. |
