Home > Maintenance & Modifications > Galvanizing
Page 1 of 3 123>
Galvanizing
Is there a great difference between hot dip galvanizing and cold galvanizing?
I have a rear ladder that will insist on corroding and I want to sort it out more or less permanently. Hot dip probably is the best especially for internal but cold galvanizing would be much much easier for me to do at home myself.
Any thought?
I've also no idea what hot dip galving would cost either.
Thumbs Up â­ï¸â­ï¸God Bless the USA 🇬🇧🇺🇸 â­ï¸â­ï¸
Post #264479 7th Sep 2013 6:33pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Hot dip is definately have done and forget but if you can do cold yourself(I have no idea what that is by the way), then that may be the way to go on small items. My local galvaniser has a minimum charge of £50, so it cost me £250 to have a chassis, body cappings, various chassis brackets and the front inner arches doing.....
My point being, a lot of stuff then have it done hot, but maybe for one or two small items then cold might be cost effective, if not as long lasting as hot.....just my two Penneth.
Post #264491 7th Sep 2013 7:59pm
I would really need to do a few bits at a time really would be easiest for me. I'm a bit tired of having to take bits off more or less each year to paint them, especially powder coated stuff.
Cold galvanizing is in a spray can and often used to protect welds and such like in existing galvanized metal.
Like this:
eBay Item No. 181112663392 â­ï¸â­ï¸God Bless the USA 🇬🇧🇺🇸 â­ï¸â­ï¸
Post #264495 7th Sep 2013 8:15pm
Jimb1978
Ah yes. The galvanisers supplied me with a can of that stuff to use in case of damage. Good job really as during the rebuild I rolled it down the drive and bent the rear crossmember. It cracked and split the galv, so I used the spray. I kept that land rover for 5 or 6 years and that part of the chassis Did not show any sign of rust. However, I am led to believe that exposed bare steel that is next to galvanised steel will corrode slower as the rust is unable to spread as quickly.
Personally, I cannot see the cold galvaniser being any better than a well prepped, etch primed and top coated finish.
In my opinion, powder coating is often done poorly. I have owned many powder coated products...some last, some don't. Sharp corners will cause powder coating to peel and rust to start. The main drawback for powder coating is you can't retreat like you can with paint.
Post #264497 7th Sep 2013 8:36pm
I do use etch primer a lot and always found it good. Do you think etch primer would be perfectly fine on its own instead?
As far as I know from what I have read up as well as it's ability to etch into materials to create a good bond apparently it is a good anti corrosion primer too.
Perhaps I should do both. Laughing â­ï¸â­ï¸God Bless the USA 🇬🇧🇺🇸 â­ï¸â­ï¸
Post #264499 7th Sep 2013 8:40pm
Jimb1978
As far as i can see, The only real benefit for cold galvanise spray is to match in with the colour of galvanised steel.
If you are painting a component to a certain colour, then etching and top coating will give just as hard wearing finish as your galvaniser spray stuff.
Post #264503 7th Sep 2013 8:49pm
I'll try etch primer only and see how that goes.
Thanks for your replies. Thumbs Up â­ï¸â­ï¸God Bless the USA 🇬🇧🇺🇸 â­ï¸â­ï¸
Post #264505 7th Sep 2013 8:58pm
Jimb1978
Sorry...just reading all that back....do not use etch primer on its own. It is designed to grip the surface of the steel to provide a base for top coat. It remains porous (for want of a better word) to enable a top coat to 'stick'
Post #264507 7th Sep 2013 9:03pm
yep that's right but it'd be etch primer base coat then clear coat. The paint side of it is fine as far as I'm concerned not worried about that at all but the corrosion problems I am, hence mentioning the cold galv.
I was originally thinking. Cold galv, etch primer, base coat and then clear coat. â­ï¸â­ï¸God Bless the USA 🇬🇧🇺🇸 â­ï¸â­ï¸
Post #264510 7th Sep 2013 9:09pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
First and foremost is getting rid of the corrosion/rust, doesn't matter what you paint on it if not removed first it will come back!
The best thing to do it in would be a product called selemix direct 70% gloss, you can get it mixed in any RAL colour and it sprays on to bare metal no primer and even if chipped after the corrosion doesn't seep further under the paint, excellent adhesion to any surface even glass!
The only problem is its a 2K product so rules out a DIY job.
Next best thing is a product called technigrip, again any colour but is single pack and can be made in aerosols or tins and no primer needed.
Best to speak to your local paint motor factor, they will point you in the right direction plus recommend any spray shops.
Bumper and cross member painted in direct gloss;
 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #264808 9th Sep 2013 11:44am
Sorry I missed your post somehow. Confused
I'm going to try as you say get rid of all existing rust, cold galv, acid etch prime, base coat and finally clear coat.
Not too worried about the actual paint finish as I know I can get that spot on but it's actually treating the steel underneath that needs to be done hence the cold galv. As is I could paint it perfectly and it'll be fine for a fair while but areas such as where the fixings are the rust will creep and then paint flake off, simply because the steel is exposed in a miniscule area where the fixings take off the paint. Which is no good at all really.
Will see how it goes. Smile â­ï¸â­ï¸God Bless the USA 🇬🇧🇺🇸 â­ï¸â­ï¸
Post #265836 11th Sep 2013 10:34pm
A regime I have used to great effect on steam restorations is to go back to bare steel (ideally wet blast, but needle gun acceptable) then use a 25% organo-phosporic acid wash, then prime, undercoat and paint. Tests have shown that the adhesion achieved by this method exceeds North Sea Oil Industry standards.
Whatever method you use make sure that you do not burnish the bare metal suface (easily done if using an angle-grinder and wire brush) since this has a significant detrimental effect on adhesion.
The phosphoric acid wash does exactly what the tradition "rust convertor" products did and converts the rust into a more stable oxide which forms a tough impervious surface layer (Fe2O3 to FeO, IIRC).
Post #265909 12th Sep 2013 7:18am
db950
The selemix direct I mentioned above is relatively new to the market but is now being used by a few of the big agricultural manufacturers where a high gloss finish is not needed, it cuts down labour time so much, shot blast old steel or degrease new steel then 2-3 coats of direct and your done! No primer and no undercoat!
Obviously 70% gloss isn't ideal for everything but they are working on a higher gloss rate, although you can cheat like I have on mine and apply 2k clear lacquer over it while its still wet to achieve full gloss.
I've done some wrought iron gates for a chap with it, perfect stuff for this kind of work and if it gets chipped the water can't seep under it due it's adhesion. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #265923 12th Sep 2013 8:45am
Just been thinking about this again tonight, mainly about hot dip galvanizing.
Anyone know roughly what it costs? I'm talking a NAS rear tow step, bumperettes, Shadow bumper and so on. All prepared for dipping. â­ï¸â­ï¸God Bless the USA 🇬🇧🇺🇸 â­ï¸â­ï¸
Post #309364 18th Feb 2014 9:34pm
AndrewS
About £160 to £200 a tonne. Usually minimum order of 1 tonne applies. If you are lucky and befriend your local Galv plant on a Saturday morning the 'dippers' may push it through for a few beers Whistle
Post #309368 18th Feb 2014 9:40pm
Page 1 of 3 123>
