Home > In Car Electronics > TD5 to Carling Hazard
farnley
Germany
lost many hours trying to get it wired , the colours I have are different to the guide that came with it , I have a record of where wires came from on std LR switch but can find no guide as to where they go, ie top right wire to position 8 on Carling the other problem is 9 wires on LR switch going to only 8 positions on the MudStuff carling switch . Should two of them be spiced if so which ones ????
any ideas ?
Post #262387 30th Aug 2013 12:24pm
Post #262389 30th Aug 2013 12:27pm
farnley
Germany
Thanks, also stripped back to original loom, kinda helps having the correct colours to look at. Now all working as it should, not that hazards mean much in the UAE other than possibly to tell everyone it is foggy!
Post #263414 3rd Sep 2013 3:19pm
excossack
How have you linked the old wires to the new Carling switch? Have you chopped the wires and resolder or found another way? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #263421 3rd Sep 2013 3:38pm
farnley
Germany
Just put connectors on he original wires into the back or the Carling hazard
Post #263440 3rd Sep 2013 4:38pm
