Home > In Car Electronics > Headunit change
spudfan
Ireland
Headunit change
I have a Pioneer headunit and six cd changer fitted to the 200 tdi, now retired. I'm considering fitting this in to the 08 Puma.Is the Pioneer unit a straight swap for the existing Land Rover unit? The next issue is running the connecting flex from the headunit to the changer. Easily enough done on the 200 tdi but not as straight forward on the Puma.Any advice. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #259103 16th Aug 2013 11:16am
You should have no problems at all. In fact the wiring maybe even easier the Pioneer should have ISO connections and so will an 08 Puma. If you haven't already got one to swap over you'll need a single DIN cage though. If you've already got one either re-use it or for the cost just get a new one.. They are cheap enough.
Thumbs Up KEEP CALM AND Drill ON
Post #259195 16th Aug 2013 7:51pm
spudfan
Ireland
Cheers. Thumbs Up 1982 88" 2.25 diesel
Post #259207 16th Aug 2013 8:06pm
If you get any problems gimme a shout and I might be able to help. Thumbs Up KEEP CALM AND Drill ON
Post #259221 16th Aug 2013 8:30pm
spudfan
Ireland
Much appreciated Thumbs Up 1982 88" 2.25 diesel
Post #259270 16th Aug 2013 10:29pm
spudfan
Ireland
Problem popped up.Seems the existing headunit has an auxillary port that enables you to plug in your mobile phone. I don't have a mobile phone but the troops do. I explained that the replacement headunit has a tape facility Mr. Green aswell as the cd changer. Anyway seems I've lost the argument.
Once again thanks for the help. 1982 88" 2.25 diesel
Post #260749 22nd Aug 2013 11:19pm
Laughing Your welcome. Thumbs Up KEEP CALM AND Drill ON
Post #260828 23rd Aug 2013 1:43pm
