Home > Puma (Tdci) > Puma Upgrade Help!!!!!
rodstir
2007 Defender 90 Puma 2.4 HT Cairns Blue
Hi Just after some advice from some one a bit more technical than myself. I have a tdci Puma that i have upgraded from a base model to a county. In the process i fitted a bulkhead loom that had ABS fitted to it unfortunatley i do not have ABS as yet but have the ABS light showing all the time. Is there a fuse that i could pull or a wire that i could disconnect to turn the light off. As this effects the MOT i could do with turning it off untill i can get the parts to fit ABS.
Thanks
Rodstir
Post #20401 18th Dec 2009 9:32am
