![]() | Home > Maintenance & Modifications > Acoustic Mat |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 ![]() |
http://www.ebay.co.uk/sch/i.html?_from=R40...amp;_rdc=1
i dont rate acoustic matting if its cut to fit, so i used a roll of rubber matting and cut that to fit my last 4x4. the thicker teh better yet the thin stuf hugs shape better, get some good quality spray glue and your sorted |
Discharge Member Since: 10 Aug 2013 Location: Dubai Posts: 54 ![]() ![]() ![]() |
I take it you've seen this: http://www.defender2.net/forum/topic17772.html
Should cost less than �300 from them? 2011 - 110 - Double-cab pick-up |
Another vote for MPS and the Dynamat system
![]() You don't have to cover 100% of the panels, give Simon at MPS a ring for advice |
think we need to establish what your tying to cover ? just the load bay ? im hard saving for sound deadning ill be focusing on the roof and load bay first then as birthdays come around ill finish the job by doing the remaining floor and the doors and side panels
Tom DCab Member Since: 13 Jun 2013 Location: West Sussex Posts: 33 ![]() ![]() ![]() |
As I have a Dcab im not too worried about rear tub.It would be for interior of cab, probably not roof and doors though..
I have had look at the link you sent to the previous post on Dynamat....Everyone seems to be buying it! Not cheap stuff though....but then maybe I wont need to much of it..... Can carpets go back down on top of it does anyone know? |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 ![]() ![]() |
It's pretty thin stuff, so carpets shouldn't be a problem.
Silent coat is the same sutff, but a lot cheaper. |
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 ![]() ![]() ![]() |
I have just done the front of mine in dynamat with the wright off road mat on top. Reduced the sound by 8db (iPhone app) big diffrence. Such a diffrence I want to do the rear seats as well. I bought a 8x4 sheet of matting from wright off road to put over the dynamat in the rear just need to find some cash for the dynamat think it was around �125 guess you could do that for the front. Defentaly dynamat though
you got a link to the matting you used ? and how much dynamat did you need for the front flooring ?
I used the moulded matting for the front. Expensive but worth it as gives a tidy finish with no carpets to get wet and muddy. I got my moulded stuff off ebay but the flat sheet from drew at wright off road (he does the molded as well) very helpful guy and gave me a copy of a land rover monthly article on fitting.
http://www.wrightoffroad.com/products.htm I ended up using a bulk pack for the front with one sheet left over thinking I will need another for the rear |
cheers for the info hopefully its helpful for the OP lol. im looking at the moulded mat for te front im just trying to find a company that does a cmplete front to rear moulded mat for the 110
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 ![]() ![]() ![]() |
are you sure that you need 450 for d-cab ? ![]() http://www.noisekillergb.com/product_details.asp?ItemID=104 www.newfoundland.gr |
