![]() | Home > Puma (Tdci) > Blower Fan Problem |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2073 ![]() ![]() |
If the air con works and the normal air heating works on
Any setting your doing well ![]() Just enjoy the air con. There's no fix as land rover have designed It that way. Steve |
GSD Member Since: 18 Dec 2012 Location: UK Posts: 38 ![]() |
![]() Thanks Steve, It all worked perfectly for the last 4 years. Aircon worked on blower setting 1, 2, or 3. My ' Rovers been fantastic so far,in fact my roof doesn't even leak. I hope my baby isn't starting to fall apart. |
Probably the resistors pack Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
I would think it would be the switch that would be the problem,if it only worked on the highest setting then the blower motor resistor would be at fault. 2005 Td5 90 XS
Steve |
The aircon by-pass the switch Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
GSD
You got to laugh ![]() My new one is just the same as my old one except i paid Twice as much for it ![]() I hope you can sort this problem out ASAP. Steve |
So its probably a case of a new switch then? Could be worse.
Thanks for the replies. |
![]() Click image to enlarge ![]() Click image to enlarge if the 0,45 ohm resistor is broken, see the electrical scheme, the speed 1 doesn't work, the 2 and 3 will work!!! Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
Ah brilliant diagram!
I've never had to get in to the heater system before. Is it a hard job? I've got the tools and I learn as I go along. Is it dashboard out? Does anyone have the part number to hand for the resister to hand. Thanks |
two screws, take-off the old one, put in the new one, easy job
before buying the new resistor, check the old one with a multimeter..... for check the resistor 1, 0,45 ohm measure the resistance from pin1 and pin2 for check the resistor 2, 0,55 ohm measure the resistance from pin2 and pin3 ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License Last edited by dgardel on 24th Jul 2013 9:33pm. Edited 2 times in total |
Sounds as if the resister pack on the heater fan blower has partly failed. Speed 3 is full current whereas speed 2 & 3 use a resistance to cut the current and give a slower speed. The resistance pack is found on the side of the heater between the electrical connector and the blower assembly and is held on by 2 screws.
![]() Blower is under the bonnet , passenger side on RHD vehicles. LANDYWATCH ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
![]() Absolutely fantastic. Thats my next to do. I love this site. Thanks for all the replies, and the very helpfull diagrams. Much appreciated. ![]() Last edited by GSD on 24th Jul 2013 10:00pm. Edited 1 time in total |
you are welcome!
Outback Engineering Service over the top!!!! ![]() ![]() ![]() ![]() IID Pro MV License |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1986 ![]() ![]() ![]() |
If I put my air con on the bower automatically starts on 1, with the slider in the off position
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
