Home > Wheels & Tyres > Fix-o-flat
caribcat
2013 Defender 110 Puma 2.2 USW Aintree Green
Fix-o-flat
I'm considering removing the spare wheel on my puma 110. I move boats around and it will make hooking up easier. It will also remove the weight off the back door, which we know by experience eventually give up the fight. The crunch came today when parked across a slight incline, the door closed on my little girl -luckily she wasn't hurt but it's an accident waiting to happen.
Locally there's not an issue but what do I do on longer (road only) trips? Don't want to chuck a wheel in the back or have to bolt it back on each time. What's the chance of getting a flat on general grabbers and is using a couple of cans of fix-o-flat as stupid as I think?
Post #19233 30th Nov 2009 10:30pm
AndrewS
Wait for Sonic's wheel carrier Thumbs Up You will have join a Q though.
Post #19237 30th Nov 2009 10:35pm
discocuzzy
Swing away carrier from Sonic that includes a gas strut to hold it open Thumbs Up
Pics coming soon You cannot teach stupid people to do clever things
Post #19243 30th Nov 2009 10:53pm
K9F
Apolgies in advance too tempting to resist......Will that be a 'two wheel capacity swing away carrier with two gas struts keeping it open' perchance???? Rolling with laughter
Just in case anyone thinks I've lost the plot the immediate post prior to this one was duplicated but has since been removed! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #19254 1st Dec 2009 8:26am
caribcat
Good point but will that help with hooking up 5-10 boats a day? It's probably still in the way. I'd prefer to find a get me home solution to a flat tire.
Tom
Post #19264 1st Dec 2009 2:50pm
Eduardo
Some people use the roof rack for the spare.
It is more dificult to put in and put out but can solve your problem with the boat.
I had the same problem with the rear door with my kids and was solved in a 99% with the swing away carrier (Mantec type) Does not have a gas truth, but the system have more resistance to be closed and therefore support more inclination and closed slowly.
Cheers Eduardo
Post #19267 1st Dec 2009 3:38pm
K9F
Get You Home Option.
Tom
Depending on how much effort you are prepared to put in to a flat tyre I am a motorcyclist and have a small compact kit that can repair a holed tyre and reinflate it afterwards. Saved my life on a Sunday in France. It involves the insertion of a rubber rivet to the tyre. You need to know where the hole is to repair it though. But couple that kit together with a can of the Fix O Flat you mentioned and I think it would be 'as good as it could get' without a spare. Any decent motorcycle shop can supply the kit that will give you about half a dozen repairs and enough small co2 bottles for a few inflations for about £30-£35.
Linky thingy:
http://www.mandp.co.uk/products/list/Tyres...Prevention If you go through life with your head in the sand....all people will see is an ar5e!!
Post #19268 1st Dec 2009 4:55pm
caribcat
Aahhhh, there we are. Much cheaper than a swing out AND I can also carry it on my GS Adventure. Good thought!
Post #19269 1st Dec 2009 5:10pm
K9F
caribcat
Just edited my last post and added a linky thingy for you to look at. This was done AFTER you wrote your reply.
Happy hunting! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #19270 1st Dec 2009 5:17pm
caribcat
Thanks for that! I'm also looking at slime which I know and depend on in mountain biking. They supply a kit which includes a pump for 4x4 tyres
Post #19271 1st Dec 2009 5:21pm
james_hillerby
I wouldnt use the slime stuff unless you can repair the tyre yourself as most tyre places wont touch a tyre after its had slime aplied so I am told.
James
Post #19274 1st Dec 2009 6:44pm
caribcat
Naaa, slime is fine... it washes right out. It the foam in the cans that can be a problem.
Post #19278 1st Dec 2009 7:30pm
Ratty
If your vehicle is designed to have a spare wheel and you don't have one you are only entitled to a 10 mile tow instead of full recovery if you get a puncture or blowout and call out a breakdown club.
Post #19483 4th Dec 2009 10:31pm
AndrewS
Sorted
There you go Thumbs Up
Post #19485 4th Dec 2009 10:55pm
