Home > In Car Electronics > ECU extension loom/lead
BigWheels
I have seen a Terrafirma one for over £300, but it was for a TD5. Shocked Seems a bit much for some wire & a plug.
Are there any cheaper that are good enough. Also what is a good higher place to put the ECU? Are any made for Pumas? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #246130 23rd Jun 2013 9:40pm
TJ101
Re: ECU extension loom/lead
TD5 looms need moving if doing a lot of wading,,
Pumas on the other hand don't seam to,, Ball ache to move anyway
How deep are you planning on regularly going ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #246145 24th Jun 2013 4:48am
BigWheels
Not reguarly, but the floods last winter made me shy away because of the ECU's positioning.
Are the accelerator electrics unaffected by flooded footwell? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #246321 24th Jun 2013 5:34pm
I highly doubt they would be unafected and I bet they aren't waterproof. Not LR's problem really eaither as they have their wading depth listed on sale / in the handbook and that depth is around halfway up the wheel IIRC or there abouts so no where near that deep. Personally I'd never take mine in anything that deep full stop. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #246464 24th Jun 2013 9:41pm
jst
td5 engine ecu is under the seat. puma one is on the bulkhead behind the instr panel. the latter i think is the best place for it, not often you get full depth of water at that point.
no point extending it to the roof as you will have more problems before it gets that deep, plus if you roll over, its at the lowest point! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #246527 25th Jun 2013 7:57am
