![]() | Home > Maintenance & Modifications > Replacing Sliding Window Seals Your Thought |
Landy-Novice Member Since: 23 Jun 2013 Location: wiltshire Posts: 118 ![]() ![]() |
when i did this, i used a load of this. http://www.woolies-trim.co.uk/p-1649-window-channel.aspx
stripped all the old seals out and fitted these. along with the fillets. job's a good'un. ![]() |
Got these for mine, still waiting for a dry day to fit them.
http://garrisonoutfitters.com/?sPath=2&prod=2 Site sponsor MPS sells them ![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
alfajock Member Since: 12 Jan 2011 Location: Bedfordshire Posts: 227 ![]() ![]() ![]() |
^^^ yep, me too. Worked perfectly 5m should do it so thirty quid and half an hour a side Fully Restored 89 110 CSW V8 CLS 350 CDI for the sensible stuff |
Drover Member Since: 27 May 2011 Location: Central Coast NSW Posts: 53 ![]() ![]() |
Replace the windows with "Gull Wings"
Simon27 Member Since: 30 Oct 2012 Location: East Lothian Posts: 131 ![]() ![]() ![]() |
Just last week I noticed for the first time a bit of a clatter from the rear windows.
What sort of work is required to strip out the old rubber channels and replace? I don't want to get half way through and find myself stuck without windows completely! |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
Take a look here...
Brilliant, thanks! Think I just found my winter project and also a chance to clear out the wildlife growing in there...
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 ![]() |
Wow I need this kit !
Stulios Member Since: 22 Jun 2013 Location: Wirral Posts: 22 ![]() ![]() |
Theres no need to remove the frame. I used the method here:
http://forums.lr4x4.com/index.php?showtopic=68899#entry589784 and the woolies trim mentioned above. 30 minutes a side easily. I didn't even remove the locks on the windows. 6 months in and all is still rattle and leak free. |
iPints Member Since: 15 Jun 2012 Location: SC Posts: 294 ![]() ![]() ![]() |
Where do you get them from??? |
