Home > Tdi > 300 tdi oil change
frenchy
300 tdi oil change
Time for (my) first oil change on Mutley.
Got the oil from Asda(bargain) the filters from the show a couple of weeks ago. Any advice as to what type of filter wrench to get on the 300tdi- will be off to Machine Mart in a bit
Thanks
Thumbs Up
Post #243792 15th Jun 2013 12:42pm
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
I've always liked the socket and strap type, machine mart code 040210245, it is a Clarke CHT245 Double drive oil filter wrench.
Regards,
Mark
Post #243800 15th Jun 2013 1:07pm
frenchy
Brilliant!!
Thanks for the advice mark Thumbs Up
Post #243803 15th Jun 2013 1:21pm
If you're well endowed, then big hands will get the filter off.
Post #243827 15th Jun 2013 2:42pm
WarPig
Dont overtighten the new filter, that way you can undo them by hand next time. Rub a bit of clean oil onto the rubber seal of the new filter to stop it seizing on.
Oh, and buy yourself a difflock drain plug to replace your oil sump plug. Next time you change your oil just connect the hose to the drain plug and the valve opens causing the oil to run out of the hose and into a suitable container. Makes life so much easier and cleaner.
Clicky here http://www.difflock.com/drainplug/
Post #243834 15th Jun 2013 3:17pm
GUM97
Completely agree with that advice, certainly is correct procedure Thumbs Up An engine to TDi for!
Post #243870 15th Jun 2013 5:13pm
jst
i tend to use the claw type that tighten onto the filter to grip it attached to a ratchet.
http://www.amazon.co.uk/AK643-Filter-Wrenc...42-4453420 Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #244028 16th Jun 2013 11:50am
frenchy
Thanks for the advice.
Ended up with a 'claw' type filter wrench that worked a treat.
Too late for the difflock sump plug but that looks great - managed to not make any mess draining the oil from the sump, but the drips from the filter gave the top of a axle a good rust proofing Wink
Did use a full roll of Kleenex stolen from the kitchen however.
Today's Jobs.......
Diesel filter
Air Filter
Drill the tub to attach the 'poppers' for the lower soft top fixings (finally get rid of the bungees holding it all together Embarassed )
Complete drilling (and paint) the windscreen header rail for the soft top fixings
http://www.trakkers.co.uk/index.php?page=s...p;Itemid=3
and all hopefully before it starts pouring down Rolling Eyes
Post #244042 16th Jun 2013 12:24pm
WarPig
Not much you can do about that is there? I always hold up a carrier bag stuffed with paper towel to the oil filter, so the filter is inside the bag, then undo it, but it still spills onto my chassis somehow!
Post #244059 16th Jun 2013 1:22pm
