Home > 130 > Longrange tank for 130?
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
Hi,
I struggle sometimes with the small range my 130 has. I am looking for an extra tank. Anyone a suggestion?
Post #243302 13th Jun 2013 6:42pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Same 'dutch boat'? Laughing
Light goes up every 530-550 km. I usually fil it up around 600 km, but I must say it can be annoying sometimes. Maybe that's because I did 900+ with a VW van. Crying or Very sad
I've seen some tanks but I couldn't say I was pleased with the looks of it.
Post #243381 13th Jun 2013 9:29pm
TopQ1967
I tow a boat. Mange only around 400 Km on a tank...
Post #243459 14th Jun 2013 7:24am
nakatanenga
Germany
There are side tanks with 75 Liter, under rear seat tank with 60 Liter and replacement tanks with 110, 130 or 160 Liters available. WANTED:
SII or SIII in max 1.5k
Post #243461 14th Jun 2013 7:27am
kjmeijer
Netherlands 2016 Defender 110 Other SW Galway Green
I manage about 650 kilometers on a tank but almost no motorways and with the Alive Stage 1 tuning. 2021 Defender 110 D300 HSE
Post #244440 17th Jun 2013 7:36pm
Juddy
Australia 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
I get around 580k from a full tank. 2010 Defender 130 HCPU
1991 110 RFSV PERENTIE
www.landybitz.com.au
Post #244838 19th Jun 2013 11:52am
wolley
2013 Defender 130 Puma 2.2 HCPU Fuji White
i fitted a tank under the rear seat with a gravity fee to a second tank under the driver seat outside/under. then a dielsel pump to the mail tank. totals about 90lts extra 110 DC, 130 DC
Post #286695 1st Dec 2013 8:03am
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
I drive a 110 DC and can't get much more than that! 600 km...most times!
nakatanenga wrote:
There are (...)110, 130 or 160 Liters available.
Are those available for 110's also? Where? Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #291192 17th Dec 2013 7:24pm
wolley
130 tanks: I had it custom made - the marked does not offer much for 130's and the 130 design surprisingly does not allow easy customisation re fuel tanks. There is a 45lt tank design that fits in-line with the 110 (gravity feed in/out), which works well, and is sufficient for basic requirements (121 lt total). In case of the 110, I carried 4 x jerry cans on top for more serious trips and found that sufficient. My 130 design makes jerry cans redundant and solves the high centre point of gravity I had with the 110 110 DC, 130 DC
Post #291209 17th Dec 2013 7:51pm
TJN
I have a140lt second tant that sit in the bed and gravity feeds into the main tank when i turn a tap. www.tektanks.com will make you a tank any size and shape you wnat. Really good they made my water tank.
Post #301537 23rd Jan 2014 4:30pm
RoyW
Netherlands
Since you're live in the Netherlands you could take a look at fuel tanks of PSP Expeditioncampers. They can provide you with a 60 + 70 extra tank(s). They will be mounted to the chasis between the crossmembers.
Worth taking a look: http://www.psp-expeditioncampers.com/produ...zt130.html
Good luck.
Roy
Post #390556 20th Jan 2015 2:50pm
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
A work of art here, but its 1500eu and its in France
http://www.outback-import.fr/en/product/3662845014627
Post #390664 20th Jan 2015 7:00pm
Mike_B
Post #390669 20th Jan 2015 7:03pm
leeds
Or up to 150 litres of fuel in one stainless steel tank from Nakatanenga here
1,195 Euro
Brendan
Post #393561 29th Jan 2015 9:03am
JimC
United States 2007 Defender 130 300 Tdi HCPU Arles Blue
I just fitted Nakatanenga's 130 l tank into my 130 this week. I honestly could not be happier with the finish of the part and it's fit. It took me six hours in total including lunch and clean-up, which I think would have gone quicker with a helper. I've only filled it with 90 liters so far because I want to ensure my fittings are tight and not leaking etc. I completely recommend these tanks.
Post #448230 22nd Aug 2015 6:29am
