![]() | Home > Puma (Tdci) > Removing storage box - 90 SVX 60th Anniversary Soft Top |
CR Member Since: 28 Jan 2010 Location: Ireland Posts: 947 ![]() ![]() ![]() |
easy job 5 minutes or less, 4 bolts that go through the chrome tie down brackets on the top. allen key required. Then just lift out
CR |
sven Member Since: 29 Dec 2011 Location: Oslo Posts: 80 ![]() ![]() ![]() |
Thanks for the tip!
I´ll see if I can get it out right now. 2009 Land Rover Defender 90 SVX Soft top 60th Anniversary Edition |
I am timing you
You were right - it took five mins
![]() Thanks again! 2009 Land Rover Defender 90 SVX Soft top 60th Anniversary Edition |
Spyman Member Since: 05 Jun 2021 Location: Beaune Posts: 4 ![]() ![]() ![]() |
Hello.
sorry to answer on an old topic. I also own an SVX soft top. But the previous owner removed this box and I am looking to buy one. It is very difficult to find. if anyone has a contact. I know that several soft top have been transformed into hard top. therefore the boxes were removed. If anyone has one to sell. Thank you in advance. Greg |
THe svx box is not very practical. Why not go for an off-the shelf drawer-box like this one - https://www.gearmate.co.uk/product/defende...ocking-pod
I have a Nakatenenga spare wheel carrier then get more load space inside. 2009 Land Rover Defender 90 SVX Soft top 60th Anniversary Edition |
Thank you very much for your answer.
also thanks for the link, that sounds like a great product and a great idea. But I want to keep the spare Wheel inside as original, so I can't find drawer-box with the right size. Today I want to have a 100 percent original vehicle for the collector's side. That's why I'm really looking for the part originally fitted. |
Ok. I have modified my car slightly and I´m not using the box. But sending it to France might be a bit expensive. 2009 Land Rover Defender 90 SVX Soft top 60th Anniversary Edition
Indeed, and can be complicated to pack correctly!
But, if you are a seller, I am still interested to have an offer from you. ![]() |
I sent you a private message.
