Home > Puma (Tdci) > Delay in turn on the main lights
Eduardo
Hi there!
Strange, but from some time to now, when I turn on the ligth switch, the main light takes about 3-4 seconds in power up it. Doesn't matter if the Defender is cool or warm, or is the first time or not: happens always.
Any thougth, maybe the relay is faulty?
By the way, the odometer is now in 70.000 Km after less than 2 years of use. So I will be with the dealers during next week.
Cheers! Eduardo
Post #18608 19th Nov 2009 12:46pm
dgardel
Italy
Re: Delay in turn on the main lights
Eduardo wrote:
Hi there!
Strange, but from some time to now, when I turn on the ligth switch, the main light takes about 3-4 seconds in turn on. Doesn't matter if the Defender is cool or warm, or is the first time or not: happens always.
Cheers!
For change it or for maintenance??? (70.000km is new!!!) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #18609 19th Nov 2009 12:49pm
Eduardo
Maintenance only...
As my grandfather said is better a known devil than one to be known Mr. Green
By the way, Defender prices here are going up to the sky in the last months. I bougth mine at the end of 2007 at GBP 16,388 (using the exchange rate of that time) and now, the same cost GBP 33,693 ... an increment of 105% Shocked Shocked
Cheers Eduardo
Post #18611 19th Nov 2009 1:05pm
