Home > Puma (Tdci) > de-cat pipe / straight through exhaust
scatt
England 2008 Defender 110 Puma 2.4 DCPU Alpine White
Has anyone tried or runs a de-cat pipe on there puma, thinking about a straight through exhaust for a tastier engine note!! dont really think it will have any major effects on performance. and i know that ive got to take the crossmember out to change it.
what are your thoughts????? should it stay or should it go??
Post #18115 10th Nov 2009 8:43pm
jst
i was under the impression - think i read it on here, that the turbo needs some back pressure from box(es) or Cat to run at optimum.
i am also thinking of a straight through system Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #18120 10th Nov 2009 8:57pm
AndrewS
I removed the centre box, that gives a deeper note. I have removed the decat on the utility but found no improvement. I think that the engine/turbo requires a bit of resistance in the exhaust to get the turbo to work properly. It needs some back pressure type thing.
Post #18121 10th Nov 2009 8:57pm
jst
Andrew - was that centre box and cat removed on the utility or cat on the utility and box on the SW? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #18123 10th Nov 2009 9:02pm
scatt
this sounds really cool, im presuming that its straight through.
Post #18126 10th Nov 2009 10:04pm
Verdone
Belgium 2007 Defender 90 Puma 2.4 HT Java Black
Ive got a decat and centre box removed makes a nice sound but not like the youtube vid i think thats with the last muffler removed aswell Laughing
Post #18134 10th Nov 2009 10:42pm
scatt
you wouldnt happen to have a vid of it, running. i would love to here the sound it makes.
Post #18135 10th Nov 2009 10:58pm
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
This one was prepared by Twisted Performance, and as far as I know uses their Tornado exhaust. Soon as my warranty runs out I'm fitting one to mine. Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #18136 10th Nov 2009 11:11pm
Defender SVX
United Kingdom 2008 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
We've got the Twisted Perormance de-cat system on the 110 dcpu and that sounds great especially with the re-map Smile I've also recentlly fitted the Twisted system to the SVX but I've only been a couple of miles since but it seems louder and a little nippier but not really tested. Also air filter and re-map soon Thumbs Up Formerly mao99999
16 Focus RS Nitrous Blue.
11 FFRR TDV8 Vouge SE Black Black.
08 DEFENDER SVX SOFT TOP (SUPERB)
08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit)
05 Fiesta ST 150 Van
04 Jaguar XKR 4.2 Supercharged V8
02 DEFENDER 90 TD5 (next years soft top project)
95 DEFENDER 110 CSW 300 TDi Phoenix black
95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi
67 109" SERIES 2a TUNED 200 TDI
64 DAVID BROWN 990 rat look
55 86" SERIES 1
Post #18139 11th Nov 2009 5:37am
AndrewS
Utility had decat pipe and centre box removed
CSW has centre box removed.
Post #18153 11th Nov 2009 10:45am
scatt
is your system on the dcpu a standard exit or is it side exit??
Post #18185 11th Nov 2009 8:32pm
Bogblaster
United Kingdom 2016 Defender 90 Puma 2.2 Adventure Corris Grey
I have the BAS de-cat and middle box removal, it is a touch loud, especially with the BAS tune. One thing Pete did say though, was "Turbo diesels don't need back pressure, only petrols"
I recently had the software updated on my 90 and when Pete re-mapped it again the noise was notably louder.
Would I de-cat it again? Yes
Would I remove the middle box? Only if Pete made a smaller one!
The noise is chuffing loud on long journeys! PM Pete, I am sure he was working on a smaller middle box, for an improved, but not really loud sound.
BB 2019 MY Disco 5 HSE Lux
Audi A4 Avant 3.0L TDI Quattro - WOW
2016 90 Adventure
Post #18197 11th Nov 2009 10:24pm
Defender SVX
Both standard exit but the 90s is a slightly larger tail pipe Wink Formerly mao99999
55 86" SERIES 1
Post #18206 12th Nov 2009 5:44am
