Home > 130 > Quadtech body's |
Juddy Member Since: 09 May 2013 Location: Queensland Posts: 63 |
Are these made from wood. 2010 Defender 130 HCPU
1991 110 RFSV PERENTIE www.landybitz.com.au |
11th May 2013 8:39am |
Link would have been handy....
Quick Google on your behalf reveals.... "Later construction with alloy frame and composite panels." So I would surmise depends on how old it is.... Couple of links: http://www.ebay.co.uk/itm/Land-Rover-Defen...1c2bdcc86e http://www.landroveraddict.com/forums/thre...;boardID=3 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
11th May 2013 9:05am |
Thanks
I have no idea how old it is but it looks like its all made of wood, with the alloy supports. [/URL] [/URL] [/URL] Click image to enlarge[/URL] Click image to enlarge[/URL] Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 2010 Defender 130 HCPU 1991 110 RFSV PERENTIE www.landybitz.com.au |
11th May 2013 9:36am |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1788 |
Wisacon???
(phenolic coated marine ply) |
11th May 2013 7:20pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
Its a certain type of wood, it has a smooth texture on both interior and exterior i think ickle got it CSK Automotive
www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
11th May 2013 7:24pm |
ok jokes aside, what wood is it made of of? 2010 Defender 130 HCPU
12th May 2013 9:59am |
^^^^ Why? Not necessarily. You need to ask the seller as looking at the pictures tells you nowt or go have a look up close if possible to see if it's crossweaved. Phenolic board is not made of wood - so nothing to rot its made of woven fabric that's pressure and pressed with phenolic resin under huge pressure, and is nigh on indestructable - attack a bit of ply with and axe it'll go through. with PB it'll bounce off it never rots, is immune to UV so doesn't breakdown that way either and is resistant to almost all petrochemicals, it's fireproof as well so almost indestructable" If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
12th May 2013 10:11am |
Thank you, I now understand what wood this is.. 2010 Defender 130 HCPU
12th May 2013 10:20am |
But it may not be 'wood' at all? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
12th May 2013 10:21am |
well wood kind of. 2010 Defender 130 HCPU
12th May 2013 10:22am |
Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
12th May 2013 10:38am |
Sonarmender Member Since: 04 Apr 2013 Location: Guz Posts: 338 |
That my friend is fibreglass coated marine ply, so yes it is wood with a coat of fibreglass on either side. This is the material of choice for 99.9% of coach builders for body construction, Phenolic Plywood is almost always used for vehicle flooring due to the cost and difficulties when painting. You only have one life, live it....forget the cost.
90XS Hardtop |
12th May 2013 11:09am |
As an apprentice, we used to make all kinds of fire engines from Wisacon, I think its a larch marine ply with a phenolic coating, I can't remember any grp strands when cut, and it took a paint finish really well.
I also made horseboxes out of similar stuff, and there are a huge amount of trucks on the road from the same. Edges had to be sealed with a grey rubbery paint, & damaged exposed edges will rot. I think another firm sent a load of fire & rescue trucks to Africa built from a Wisacon type material in the late 70's - apparently the local termite population did a very good job of lightening the construction somewhat! Keith |
12th May 2013 11:49am |
roamingman Member Since: 15 Mar 2012 Location: nearly thier Posts: 152 |
Mine has steel frame wood on inside alloy and steel out side,
see gallery. Live Life Ti'l You Die Teddys are out thier http://teddybearspicnic.webs.com http://130sasha.co.uk/ |
12th May 2013 2:41pm |
