Home > My Defender > What Did You Do In Your Defender Today |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5850 |
After a drive yesterday, I am not 100% convinced on the extra height the rails give.
I am not sure if its something I need time to get used to or not. If I am sticking with the extra height then I need to alter the cubby box height as now its too low. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
15th Nov 2023 9:38am |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1364 |
i had rails, i fit them when i bought it, then removed them a year later and don't feel like i need them now
15th Nov 2023 12:05pm |
I need to give the rails a bit longer to see if I can get comfortable with them. 1999 Defender TD5 110
15th Nov 2023 12:10pm |
Fitted a new alternator to Miffy... 18.6v at 3000rpm = engine into limp mode
15th Nov 2023 4:05pm |
Errr...Thats not quite right. What make did you go for ? 1999 Defender TD5 110
15th Nov 2023 4:15pm |
Hi John, I went for a Hella in the end as I could not get a Denso in time and Hella is supposed to be a decent 'safe' brand. Apparently made in Germany. What could go wrong eh?!
Tell you what though, the TD5 does not like 18v Gauges do some weird things. No fault codes though. I will get it sorted tomorrow. |
15th Nov 2023 5:24pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2105 |
Should go faster thoughβ¦
When I upgraded by cordless drill from a 12v model to an 18v model it was an improvement all round - you just need to give it time⦠|
15th Nov 2023 6:08pm |
Ha just been looking back at the video... 19.3v...
Heated seat has never been so warm... Click image to enlarge Click image to enlarge Click image to enlarge Yikes..... |
15th Nov 2023 6:15pm |
Cra1gSG Member Since: 01 Nov 2023 Location: South Lanarkshire, Scotland Posts: 28 |
Well the work wasn't today, more like over the past week or so!
Here's what's been done .... "Pickaxe" getting some TLC & modz! π What started out as a treat for her after Mudmaster evolved into some other jobs and modz π Iv fitted the new following parts ... β Allisport air intake pipe. β Water pump β Allisport exhaust manifold & stud kit. β Full set of Roose blue silicone hoses. β Allisport header tank β Allisport rocker cover & header tank caps. β New belt tensioner. β Clean & Intercooler. β Change & modify airbox to a twin inlet. Also removed the cyclone. β Fabricate another air inlet intake for n/s wing. β Fit and run air intake on n/s. β Weld on brackets then fit S/S Bush wire kit β Oil & filter / service plus new antifreeze etc. Click image to enlarge ββββββ "ππππ ππ πππ πππ, ππππ πππ πππππ πππ!" ββββββ π€ |
15th Nov 2023 9:10pm |
Ooh Allisportβ¦
Nice header tank (nice everything to be fair). And youβve got the sight glass |
15th Nov 2023 9:39pm |
Thank you Screbble π
All the jobs evolved into "well I may aswell just do it while I'm here" ππ» ββββββ "ππππ ππ πππ πππ, ππππ πππ πππππ πππ!" ββββββ π€ |
15th Nov 2023 9:44pm |
I am not surprised the TD5 doesn't like 18v Hella lot of voltage..... 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
16th Nov 2023 9:06am |
Ha... Well all is back to where it should be. Picked up the replacement replacement alternator and Miffy is now being supplied with a consistent 14v +/-. Good for another 200k miles or so |
16th Nov 2023 2:28pm |
14v FTW! 1999 Defender TD5 110
16th Nov 2023 2:49pm |
