Page 1327 of 1380 <123 ... 132613271328 ... 137813791380>
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Got round to making myself a rear upper speaker panel!
Post #938730 21st Jan 2022 7:44pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
Been very remiss at putting anything on this page for a while but today I took the old girl down to Chichester and back for a run (needed to go for work with limited tools).
Since she has been off the road for a while MOT expired and knew it needed new track rod ends (why do the rubber boots perish so quickly on them?) then remembered it needed the timing belt doing (possibly nearly 2 years overdue..... slap wrists moment).
All of this has been sorted for a couple of weeks and she's been driven a bit more I started to remember things that weren't quite right but not bad enough to warrant getting too cold to sort out, but enough is enough so it was time to sort it.
In the last couple of weeks the list of things I've done are as follows:
-Track Rod Ends
-New Double DIN Pioneer head unit (replaces Single DIN and separate camera screen) strangely this didn't sort the missing bass so.....
-In Phase USW10 mounted to rear of cubby (that's better)
-New Carling style rocker switches to replace the failing Exmoor Trim ones (they have done 7 years so can't complain) have been purchased with a view to fitting tomorrow
-Shopping list of replacement Carling rockers with logo's for RWW, Worklight, Light Bar, Heated Seats and reversing Camera has been drawn up which should make the Consoles look better (they're currently all unlabelled except the RWW).
-Snapped the plastic on the key so bought the Bling stainless One (probably Britpart or Exmoor Trim not really sure) fitted that this evening.
I think it's just time to drive her and enjoy her for a bit (after the seat heater switches are replaced tomorrow). 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #938733 21st Jan 2022 8:19pm
L110CDL
Thanks for the update Phil Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #938746 21st Jan 2022 9:05pm
Cubflyer
United Kingdom 1994 Defender 90 300 Tdi SW Arles Blue
Found an Oil Leak Crying or Very sad Exclamation
Any comments as to actual part or previous experience of a leak in this area welcomed!
MTIA
John 2010 Defender 90 300Tdi CW (White/1994)
2021 Defender 90 300Tdi SW (Blue/1994)
Post #938757 21st Jan 2022 10:17pm
landy andy
Power steering pump and then getting blown around by fan I think.
Post #938766 21st Jan 2022 11:48pm
Cubflyer
Thanks Andy, just looked at a service manual and yes - Steering pump area/pipes. Thumbs Up
Oil must be filty Exclamation 2010 Defender 90 300Tdi CW (White/1994)
Post #938769 22nd Jan 2022 12:03am
Dinnu
No connection with the guys, but these are boots that last. Just replace them on new ball joints, and no worries for a very long time.
https://gwynlewis4x4.co.uk/product/polyure...ur-gl1173/ 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #938780 22nd Jan 2022 6:56am
300TDi CSW Phil
Thanks for the link. Not sure why I hadn't thought of checking their website having a few Gwynn Lewis bits on the truck 1995 300 Tdi Epsom Green - It's a keeper.
M0XQS
Post #938786 22nd Jan 2022 8:02am
landy andy
Looking better at pic now you can see the area has a red tinge on it. The leak might just be that crappy looking jubilee clip, and then being blown around by the fan if your lucky.
Post #938788 22nd Jan 2022 8:17am
landy andy
Agree that the Gwyn ones are good and come with grease nipple, so be maintained.
Post #938789 22nd Jan 2022 8:18am
Sulisuli
Little run out to the coast with Roy5695 after a morning of fitting Optimill bits to my defender (thanks Roy)
Photos courtesy of Roy Thumbs Up
 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #941185 5th Feb 2022 8:55pm
leonvh
Belgium 2013 Defender 110 Puma 2.2 SW Barolo Black
From this mess:
To this somewhat improved mess:
And this instead of the Alpine flip-out unit:
I really wanted to have Apple CarPlay (wireless) and it seems to work fine. Still figuring out how everything works (TPMS, DAB+, OBDII). Added some additional USB's as well:
And the camera's I already had are still working fine:
Post #941602 8th Feb 2022 11:12am
leonvh
Sorry, double-click resulted in duplicate post.
Post #941603 8th Feb 2022 11:13am
jaygti
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
From this:
To this:
The bits of the bumper you can’t see were even worse than the bits you can see. 2002 td5 90 county hardtop
Post #941632 8th Feb 2022 1:08pm
jaygti
From this:
To this:
Post #941633 8th Feb 2022 1:08pm
